New Base version D-BL-1C with doubled memory capacity
DOMIQ
#1 New Base version D-BL-1C with doubled memory capacity
Beitragvon DOMIQ » Fr 24. Apr 2015, 13:35
We would like to share information about new model of the Base module: D-BL-1C.
There are two main changes:
  • RAM memory doubled, from 8MB to 16MB
  • FLASH memory doubled, from 4MB to 8MB
While memory is doubled, the actual area for user application is actually tripled, due to the operating system memory requirements that didn’t change. All software releases we prepare are universal, that is the same rtos, system and web components can be installed in both models.
New Base model is recommended for customers with very advanced installations, larger visualizations, multiple extension modules or where large number of BACnet variables is used - installations like those frequently were implemented with multiple Base modules. Model D-BL-1B is available for smaller installations and its’ price does not change.
Below summary of RAM and FLASH memory and free space after Base is started.
D-BL-1B
#> heap stat
USED     total=2195364        largest=32772 count=30143
FREE      total=1718240        largest=1605400 count=633
TOTAL  total=3913604        largest=1605400 count=30776
#> fstat FLASH0
Filesystem:   FLASH0
Total size:   2767 KiB
Free size:    1462 KiB
Used size:    1305 KiB
D-BL-1C
#> heap stat
USED     total=1892296        largest=32772 count=26144
FREE      total=9043696        largest=8846492 count=792
TOTAL  total=10935992      largest=8846492 count=26936
#> fstat FLASH0
Filesystem:   FLASH0
Total size:   6703 KiB
Free size:    5403 KiB
Used size:    1300 KiB
Nils
Danksagung erhalten: 15 Mal
#2 RE: New Base version D-BL-1C with doubled memory capacity
Beitragvon Nils » Sa 25. Apr 2015, 14:15
Hallo Zusammen,
der Preis für das neue Modul wird in der Liste 1071€ inkl. Mehrwertsteuern sein. Demnächst wird es entsprechend im Shop gelistet sein.
Für eine erste Lagerbestellung würde ich gerne wissen, wer daran Interesse hat. Lieferbar wären sie frühestens ab ca. KW19, wenn eine entprechende Anzahl zusammenkommt.
Als Einführungspreis biete ich das Modul bis zum 03.05.2015 für nur 899,00€ inkl. Steuern und Versand oder für nur 999,00€ mit 3 zusätzlichen Remote-Lizenzen an.
Bestellungen bitte über das Kontaktformular.
Nils (Gresbrand)
#3 RE: New Base version D-BL-1C with doubled memory capacity
Beitragvon Beleuchtfix » Sa 25. Apr 2015, 15:50
Wird es eventuell ein Upgrade Angebot geben, alt gegen neu für X Euronen?
Nils
#4 RE: New Base version D-BL-1C with doubled memory capacity
Beitragvon Nils » Mo 27. Apr 2015, 09:46
Moin Florian,
das hatte ich auch schon überlegt, vielleicht ginge das:
Bei Rückgabe eines max. ein Jahre alten Base gibt es die größere Version für nur 399€ Zuzahlung inkl. Porto und Mehrwertsteuer (unabhängigt von den sonstigen Zahlungskonditionen). Angebot wäre gültig bis zum 29.05.2015. Wäre das interessant?
An sonsten empfehle ich den Marktplatz ;)
Nils (Gresbrand)
#5 RE: New Base version D-BL-1C with doubled memory capacity
Beitragvon Beleuchtfix » Mo 27. Apr 2015, 10:35
nils hat geschrieben:Wäre das interessant?
Im Prinzip ja, aber meine sind zu alt. danke
