Guten Morgen,
Gibt's eine Möglichkeit das Base komplett zu löschen,
Dh. eine Art factory-reset?
Domiq base reset/factory
Themenersteller - Mitglied
#3 Re: Domiq base reset/factory
It's possible to do that using telnet. After you connect Base using telnet just type: format FLASH0 Confirm and press enter. Base will erase entire flash memory (all configuration and other user settings). After that it will start downloading software from our server, so active internet connection is required.
If for any reason this procedure fails (especially when software download is interrupted), then there is recovery mode, so don't worry
In that case, please contact us.
