Hi Filip,
is there a chance to create a button in display:
1) Individually setup for hit-make-brake commands
2) a label
3) a channel for the return value be used by themes
I think, you are already using all of these features in different control, a combined button would allow to use the LCN features like the real buttons. Feature 3 would be nice, but I desperately need features one and two.
Regards Florian
Feature request
DOMIQ
#2 RE: Feature request
Hi Florian, this is exactly how we want to extend the Display. Just don't know for now when we will change it to work like that, as it requires changes in all components...
#3 RE: Feature request
Hi Filip,
do you think there is a chance for a quick and dirty button with hit / make / break ? I desperately need it for my church project, since primary operation will be done by display.
Regards Florian
Regards Florian
DOMIQ
#4 RE: Feature request
OK, I will check out how it would be possible to add it much sooner. Possibly we will change switch element, so there will be hit, make, break commands, and exisiting command would be interpreted as hit.
#5 RE: Feature request
That is exactly what I need and would be very compatible for existing installations.
Regards Florian
Regards Florian
