Base & SONOS
DOMIQ
#31 RE: Base & SONOS
Beitragvon DOMIQ » So 12. Feb 2012, 18:33
Great. For SONOS, we actually have SOAP stack inside the Base, so it's not very complicated internally. It's more effort in actual mapping of UPnP variables into channels and commands, that would be easy to use and powerful.
Franky
#32 RE: Base & SONOS
Beitragvon Franky » Fr 17. Feb 2012, 21:36
DOMIQ hat geschrieben:It's more effort in actual mapping of UPnP variables into channels and commands, that would be easy to use and powerful.
Do you have a tutorial or examples of the UPnP-channels? :)
DOMIQ
#33 RE: Base & SONOS
Beitragvon DOMIQ » Sa 18. Feb 2012, 16:04
It's deactivated currently. Little patience, it will come in 1.7.6 :-)
norden
#34 RE: Base & SONOS
Beitragvon norden » Do 8. Nov 2012, 23:42
Hej Filip,
do you have any news about sonos ?
Bye
Dieter
#35 RE: Base & SONOS
Beitragvon Thomas » Fr 9. Nov 2012, 08:19
Sonos, direkt vom Base steuern, hätte was.
Im Moment behelfe ich mir mit macros auf der LinHK,
die hinter Tasten im LCN liegen, und vom Base ausgelöst werden.
#36 RE: Base & SONOS
Beitragvon Thomas » Fr 9. Nov 2012, 19:10
Ein LinHK Beispiel für einen sleeptimer (5 Minuten) per BMI ausgelöst :
sleeptimer.txt:
POST /MediaRenderer/AVTransport/Control HTTP/1.1
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#ConfigureSleepTimer"
CONTENT-TYPE: text/xml ; charset="utf-8"
HOST: 192.168.1.37:1400
Content-Length: 422
         0
         0:5:0
buero_play.txt:
CONNECTION: close
CONTENT-LENGTH: 266
CONTENT-TYPE: text/xml; charset="utf-8"
SOAPACTION: "urn:schemas-upnp-org:service:AVTransport:1#Play"
01';
Makro :
#! /bin/sh
# Timer 5min
cd /var/media/NEW_LINK/linhk
./netcat 192.168.1.37 1400 /dev/null
Spielt den letzten eingestellten Sender.
DOMIQ
#37 RE: Base & SONOS
Beitragvon DOMIQ » Sa 10. Nov 2012, 12:51
I will quickly add SOAP and HTTP calls API for Logic.
It's not as nice as what we plan, but time flies and this would be usable for other things as well.
One thing I need to assure, is that it is loaded only when used, not to waste memory I all Bases...
DOMIQ
#38 RE: Base & SONOS
Beitragvon DOMIQ » Mi 14. Nov 2012, 07:36
OK, I took the challenge!
Next week we will have first beta of proper SONOS support.
norden
#39 RE: Base & SONOS
Beitragvon norden » Mi 14. Nov 2012, 16:40
:thumbup:
Dieter
norden
#40 RE: Base & SONOS
Beitragvon norden » Sa 24. Nov 2012, 23:34
Hej Flip,
what do you think? Do you win the challenge? :)
All the best
Dieter
