Domiq Display über webbrowser und App regelmäßig nicht erreichbar
DOMIQ-Support
#11 Re: Domiq Display über webbrowser und App regelmäßig nicht erreichbar
You should be able to reach the configurator with all kind of browsers, but you need to make sure that the Flash plugin is up to date and enabled. For example Chrome requires to add rule to allow Base to use FLASH plugin. Next year we will migrate from Flash.
