Air Display
maricht
#11 RE: Air Display
Beitragvon maricht » Mi 16. Jan 2013, 13:53
gibst du bitte bescheid wenn sich da etwas zum positiven entwickelt ?
Danke Matthias
#12 RE: Air Display
Beitragvon Thomas » Mi 16. Jan 2013, 15:49
Hallo Matthias,
habe bis jetzt noch keine Info von Filip bekommen.
DOMIQ
#13 RE: Air Display
Beitragvon DOMIQ » So 20. Jan 2013, 20:18
Hello, it will take few more weeks, but there will be new AirDisplay soon, version 1.8.0.
Within a week or two it will be possible to do some preliminary alpha version testing. Most important change is introduction of DEAP server, which should enable remote operation after pairing as with Remote. We will need to test it with multiple routers etc to make sure it works properly, as well as to make sure all configuration loading bugs were found.
thw-it
#14 RE: Air Display
Beitragvon thw-it » Do 1. Aug 2013, 02:46
Filip,
i just updated Adobe Air and installed Air Display 1.8 which has been published recently. Furthermore i updated the firmware of my base. However i don't get Air Display running, for whatever reason it stuck right after i fire it up. I don't even get to the point to enter user/pw. I tried to get it running on an Win7 Professional machine so basically nothing special, right?
Any feedback is much appreciated.
cya
Stefan
DOMIQ
#15 RE: Air Display
Beitragvon DOMIQ » Do 1. Aug 2013, 11:11
Will check. Please note that version 1.8 will ask for pairing code, just as for Remote. No license will be used though.
You can try to re-save the Display tab in Configurator, this will force data refresh in AirDisplay.
mr_claus
Danksagung erhalten: 4 Mal
#16 RE: Air Display
Beitragvon mr_claus » So 29. Dez 2013, 18:43
It still does not work here, where i can put in the paring code in Air Display?
#17 RE: Air Display
Beitragvon Beleuchtfix » So 29. Dez 2013, 19:02
Soweit ich mich erinnere, musst du keinen Code eingeben. Du benötigst noch eine Frei Lizenz und dann greift sich das Air Display beim ersten Öffnen die Lizenz.
#18 RE: Air Display
Beitragvon Beleuchtfix » Mo 20. Jan 2014, 12:16
Hi Piotr
I just updated Air today including Adobe Air to newest version. I could pair air display, but will not get beyond the Domiq start page.
Is air display working at the moment?
Any hints?
Regards Florian
maricht
#19 RE: Air Display
Beitragvon maricht » Sa 15. Mär 2014, 21:02
Naja leider etwas extrem unzuverlässig der Support von diesem Herrn Filip. Es geht nach wie vor nicht. :thumbdown:
#20 RE: Air Display
Beitragvon Uwe » Sa 15. Mär 2014, 23:18
[zitat]... leider etwas extrem unzuverlässig ...[/zitat]
Das sehe ich aber gänzlich anders.
Allerdings: ich kenne bislang niemanden der das AirDisplay mit Erfolg betreibt. Gibt es da jemanden?
Ansonsten wäre für mich nach der deutschen Version des Handbuchs (:thumbup: ) mal ein "How to" für AirDisplay dran ;)
Grüße, Uwe - der dem Herrn Filip aber nicht seine Prioritäten durcheinanderbringen will :D
