Seite 5 von 5
#41 RE: Werte aus Elsner Wetterstation über Domiq Base
Verfasst: Mo 19. Aug 2013, 11:47
DOMIQ-Support hat geschrieben:3. An identifier without prefix is the state of identifier. The Condition field should always refer the the state of identifiers.
Fall Du da auch einen Event benutzen würdest, müssten beide Ereignisse 100%tig gleichzeitg ausfallen, deshalb nur den Status verwenden.
#42 RE: Werte aus Elsner Wetterstation über Domiq Base
Verfasst: Mo 19. Aug 2013, 12:00
von tinu
Hi Piotr
I adjusted my settings according your proposal (see attached file) and it's working :) . Thank you very much.
Kind regards
Martin
#43 RE: Werte aus Elsner Wetterstation über Domiq Base
Verfasst: Mo 19. Aug 2013, 12:03
von tinu
DOMIQ-Support hat geschrieben:Hello, You can't do something like this:) The Data field must be filled by some explicit value or by a pattern (see pattern chapter in the Base configuration manual). It can't call value of some other variable. You can set MEM.sonne_west via Remote and compare its value with the Data value in the Condition. To do such thing put the following code in the Condition field: $D0>MEM.sonne_west. I hope this helps to solve your issue:)
Oh, I almost forgot: to use this example, you need to leave the Data field blank. $D0 means the value that triggered the event.
Hi Piotr
Kind regards
Martin
#44 RE: Werte aus Elsner Wetterstation über Domiq Base
Verfasst: Di 20. Aug 2013, 08:04
von DOMIQ-Support
Good to hear that:)
