LUA for Base (transferiert aus anderer Themenkette - von Nils zur besseren Übersicht)
DOMIQ
#1 LUA for Base (transferiert aus anderer Themenkette - von Nils zur besseren Übersicht)
Beitragvon DOMIQ » Mi 22. Sep 2010, 22:22
Larger example - I'm attaching two files (well, I tired, results below), that should be loaded to scripts directory on the Base. They can later be loaded by "import" call. Latest modules have those files by default.
[warn]pwm.lua ist kein erlaubter Dateityp.
pid.lua ist kein erlaubter Dateityp.[/warn]
  • pwm.lua implements PWM modulation for outputs, that lets use PWM with older LCN modules and simple radiator regulators.
  • pid.lua implements PID regulator, I actually use it at home instead of built-in proportional regulators of LCN modules. For now mostly because of PWM
This is how to use both together:
import 'pid'
import 'pwm'
pid {
  kp = 10, trace=true,
  positive = pwm { output = use "LCN.output.0.110.2", period = 360},
  value = use "LCN.value.0.110.r1",
  regulator = use "LCN.regulator.0.110.1"
Above code configures PWM output on module 110, output 2 with full cycle equal to 6 minutes. It uses temperature from R1 on module 110 as current temperature, and regulator 1 setting on module 110 as setpoint value.
There are more options to setup, like integration and derivation constants. I need to extend pid.lua with regulator autotuning...
Another option, that could have nice results (I will check this winter) would be to use LCN regulator to control temperature of the radiator in the room and then use above PID regulator (with small changes) to vary temperature of the radiator by changing setpoint inside LCN module. This of course would require two temperature sensors per room, one like now and second stuck to the radiator.
Such setup is frequently used in automation, and should make temperature stabilization much better. And get rid of "cool flow" of air from the windows to floor, which for me is major issue with current LCN setup, especially that "standard" way of radiator control doesn't suffer that problem.
DOMIQ
#2 RE: LUA for Base (transferiert aus anderer Themenkette - von Nils zur besseren Übersicht)
Beitragvon DOMIQ » Mi 22. Sep 2010, 22:29
This is pwm.lua, so you can see how it looks like. pid.lua is much longer, but generally doesn't use anything different.
-- PWM Output Module
-- Copyright 2010 DOMIQ Sp. z o.o.
function pwm(tab)
        local dev = {}
        local out = assert(tab.output)
        local per = assert(tab.period)
        local ontime = 0
        local pertime = 0
        local curtime = 0
        dev.value = 0
        dev.trace = tab.trace
        function out:ontick()
                curtime = curtime + 1
                if curtime > per then curtime = 0 end
                ontime = (dev.value * per)/100
                if ontime  per then ontime = per end
                if dev.trace then
                        print(string.format("PWM: out=%d curtime=%d ontime=%d period=%d",out.value,curtime,ontime,per))
                end
                if curtime  ontime and out.value > 0 then out:off() return end
        end
        function dev:set(val)
                print("PWM: value="..val)
                local v
                if val == "on" then
                        v = 100
                elseif val == "off" then
                        v = 0
                else
                        v = tonumber(val)
                end
                assert(v >= 0)
                assert(v <= 100)
                if dev.value == 0 then
                        curtime = 0
                end
                dev.value = val
        end
        function dev:get()
                return dev.value
        end
        out:off()
        return dev
end
Nils
Danksagung erhalten: 15 Mal
#3 RE: LUA for Base (transferiert aus anderer Themenkette - von Nils zur besseren Übersicht)
Beitragvon Nils » Do 23. Sep 2010, 07:57
Hi Filip,
I transfered this new theme for a better overview ;-)
The upload didn't work because of wrong ending. Please send me the files per mail ans I will add them.
Regards
Nils (Gresbrand)
DOMIQ
#4 RE: LUA for Base (transferiert aus anderer Themenkette - von Nils zur besseren Übersicht)
Beitragvon DOMIQ » Fr 22. Apr 2011, 22:46
How to act on change:
sth = use 'LCN.output.0.20.1'
function sth:onchange(new,old)
  print("New value",new,"Old value",old)
end
If you don't need old or new value, you might ignore it. Also, if you need to monitor number of values for change, do it like that:
val1 = use 'LCN.relay.0.20.1'
val2 = use 'LCN.relay.0.20.2'
function changed()
  if val1.value == 1 and val2.value == 1 then
    print("Both are ON")
  end
end
val1.onchange = changed
val2.onchange = changed
