#1 Integration with Shelly | Update: 2.0.4.0
Verfasst: Do 7. Jul 2022, 10:31
von DOMIQ-Support
Yesterday we published an update for Base modules. The main feature of this update is integration with Shelly devices.
Full list of changes:
https://domiq.eu/news/update_2.0.4.0
Tutorial about integration with Shelly:
https://domiq.eu/tutorials/tu_0029
#2 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Do 7. Jul 2022, 15:41
von norden
I just tested it , Great Job
best regards
Dieter
#3 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Sa 9. Jul 2022, 13:57
von BerndKorzineck
Great job! Works good and easy to configure!!!
Tested with an Shelly One V3.
#4 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Sa 9. Jul 2022, 16:02
von BerndKorzineck
I already have a problem...
As soon as a Shelly module is de-energized and then reconnected to power, you cannot send a switching command via MQTT from the DOMIQ. If you switch to the web interface on the Shelly module itself, the status is displayed on the DOMIQ. However, switching does not work on the DOMIQ after a power failure on the Shelly Module.
#5 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: So 10. Jul 2022, 09:53
von norden
I have the same problem. After rebooting the Base every think works fine.
#6 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Mi 13. Jul 2022, 09:39
von DOMIQ-Support
BerndKorzineck hat geschrieben:I already have a problem...
We will check this, because we haven't observed such behaviour during testing.
UPDATE 1: We checked it and it's as you reported. This is a bug in Shelly devices - they do not send the MQTT disconnect packet as required by the MQTT standard. Only the 1st generation of Shelly devices have this issue. The 2nd gen. devices behave properly.
We will include a patch to handle this in Base.
UPDATE 2: Issue is already fixed, we will release minor update ASAP.
#7 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Mi 13. Jul 2022, 11:04
von DOMIQ-Support
Besides this issue, what are your first impressions regarding using Shelly with Base?:)
#8 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Mi 13. Jul 2022, 14:43
von DOMIQ-Support
Update (ver. 2.0.4.1) is already online
#9 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Mi 13. Jul 2022, 15:06
von BerndKorzineck
DOMIQ-Support hat geschrieben:Besides this issue, what are your first impressions regarding using Shelly with Base?:)
Super easy integration into DOMIQ.
So far, Shelly One has been implemented as a single switch and Shelly RGB2. Here I have already written my positive experiences in my post from July 11th, 2022.
http://forum.bus-profi.com/viewtopic.php?f=8&t=7597
#10 Re: Integration with Shelly | Update: 2.0.4.0
Verfasst: Di 19. Jul 2022, 20:29
von Andre-sv650
Wow,
i have not expected such a big change. I have no shelly devices, but what i have seen is, that they are not expensive and the integration is now super easy.
I think i will buy some and check it, LCN is really expensive and for example there is no plugin with current measurement.
Really a big thanks to Domiq for the support and the update.
Andre
