#4 RE: PCHK 2.7 - segmentation fault unter Ubuntu 14.04.2
Verfasst: Mi 25. Feb 2015, 15:46
von taa
Hier noch ein vollständiger Output von strace (mit ein paar "geschwärzten" Daten):
execve("./lcnpchk", ["./lcnpchk", "-nodaemon"], [/* 15 vars */]) = 0
uname({sys="Linux", node="server", ...}) = 0
brk(0) = 0x9a7d000
brk(0x9a7dd80) = 0x9a7dd80
set_thread_area({entry_number:-1 -> 6, base_addr:0x9a7d880, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}) = 0
set_tid_address(0x9a7d8e8) = 12569
set_robust_list(0x9a7d8f0, 12) = 0
futex(0xbff6d838, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 1, NULL, 9a7d880) = -1 EAGAIN (Resource temporarily unavailable)
rt_sigaction(SIGRTMIN, {0x8201ef0, [], SA_SIGINFO}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x8201f70, [], SA_RESTART|SA_SIGINFO}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0x9a9ed80) = 0x9a9ed80
brk(0x9a9f000) = 0x9a9f000
futex(0x836ec5c, FUTEX_WAKE_PRIVATE, 2147483647) = 0
pipe([3, 4]) = 0
ioctl(3, FIONBIO, [1]) = 0
pipe([5, 6]) = 0
ioctl(5, FIONBIO, [1]) = 0
write(6, "\0", 1) = 1
gettimeofday({1424875003, 618500}, NULL) = 0
gettimeofday({1424875003, 618802}, NULL) = 0
gettimeofday({1424875003, 619035}, NULL) = 0
read(3, 0xbff6d2bf, 1) = -1 EAGAIN (Resource temporarily unavailable)
mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0xb77d8000
mprotect(0xb77d8000, 4096, PROT_NONE) = 0
clone(child_stack=0xb77df2a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb77dfba8, {entry_number:6, base_addr:0xb77dfb40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb77dfba8) = 12570
Process 12570 attached
[pid 12570] set_robust_list(0xb77dfbb0, 12) = 0
[pid 12569] gettimeofday(
[pid 12570] futex(0x836e124, FUTEX_WAIT_PRIVATE, 2, NULL
[pid 12569] {1424875003, 620605}, NULL) = 0
[pid 12569] futex(0x836e124, FUTEX_WAKE_PRIVATE, 1
[pid 12570] ) = 0
[pid 12570] gettimeofday(
[pid 12569] ) = 1
[pid 12570] {1424875003, 621164}, NULL) = 0
[pid 12569] mkdir("Log/", 0755
[pid 12570] futex(0x836e124, FUTEX_WAKE_PRIVATE, 1
[pid 12569] ) = -1 EEXIST (File exists)
[pid 12570] ) = 0
[pid 12569] pipe(
[pid 12569] [7, 8]) = 0
[pid 12570] {1424875003, 621919}, NULL) = 0
[pid 12569] ioctl(7, FIONBIO
[pid 12569] , [1]) = 0
[pid 12570] {1424875003, 622253}, NULL) = 0
[pid 12569] write(8, "\0", 1
[pid 12570] select(6, [3 5], NULL, NULL, {0, 249000}
[pid 12569] ) = 1
[pid 12570] ) = 1 (in [5], left {0, 248993})
[pid 12570] read(5,
[pid 12569] {1424875003, 623110}, NULL) = 0
[pid 12570] "\0", 1) = 1
[pid 12569] read(7,
[pid 12569] "\0", 1) = 1
[pid 12570] {1424875003, 623526}, NULL) = 0
[pid 12569] mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0
[pid 12569] ) = 0xb77d0000
[pid 12570] {1424875003, 623881}, NULL) = 0
[pid 12569] mprotect(0xb77d0000, 4096, PROT_NONE
[pid 12569] ) = 0
[pid 12570] {1424875003, 624309}, NULL) = 0
[pid 12569] clone(
[pid 12570] select(6, [3 5], NULL, NULL, {0, 247000}Process 12571 attached
[pid 12571] set_robust_list(0xb77d7bb0, 12
[pid 12569] child_stack=0xb77d72a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb77d7ba8, {entry_number:6, base_addr:0xb77d7b40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb77d7ba8) = 12571
[pid 12571] ) = 0
[pid 12569] time(NULL) = 1424875003
[pid 12571] time(
[pid 12569] futex(0x9a7eb20, FUTEX_WAIT_PRIVATE, 2, NULL
[pid 12571] NULL) = 1424875003
[pid 12571] time(NULL) = 1424875003
[pid 12571] open("/sys/devices/system/cpu/online", O_RDONLY|O_CLOEXEC) = 9
[pid 12571] read(9, "0-3\n", 8192) = 4
[pid 12571] close(9) = 0
[pid 12571] mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0xb75d0000
[pid 12571] munmap(0xb75d0000, 196608) = 0
[pid 12571] munmap(0xb7700000, 851968) = 0
[pid 12571] mprotect(0xb7600000, 135168, PROT_READ|PROT_WRITE) = 0
[pid 12571] openat(AT_FDCWD, "Log/", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY|O_CLOEXEC) = 9
[pid 12571] getdents(9, /* 14 entries */, 32768) = 656
[pid 12571] open("Log/messageLogger_2015-02-25T14-46-26.xml", O_RDONLY) = 10
[pid 12571] fstat64(10, {st_mode=S_IFREG|0644, st_size=459, ...}) = 0
[pid 12571] close(10) = 0
[pid 12571] open("Log/messageLogger_2015-02-25T14-49-47.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-30-50.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T15-10-42.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-10-05.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-12-04.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-10-30.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-46-43.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-07-34.xml", O_RDONLY) = 10
[pid 12571] open("Log/.", O_RDONLY) = 10
[pid 12571] fstat64(10, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 12571] open("Log/messageLogger_2015-02-25T14-30-54.xml", O_RDONLY) = 10
[pid 12571] open("Log/..", O_RDONLY) = 10
[pid 12571] fstat64(10, {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
[pid 12571] open("Log/messageLogger_2015-02-25T14-10-46.xml", O_RDONLY) = 10
[pid 12571] open("Log/messageLogger_2015-02-25T14-49-40.xml", O_RDONLY) = 10
[pid 12571] getdents(9, /* 0 entries */, 32768) = 0
[pid 12571] open("/etc/localtime", O_RDONLY|O_CLOEXEC) = 9
[pid 12571] fstat64(9, {st_mode=S_IFREG|0644, st_size=2309, ...}) = 0
[pid 12571] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb77cf000
[pid 12571] read(9, "TZif2\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\10\0\0\0\10\0\0\0\0\0\0\0\220\0\0\0\10\0\0\0\16\233\f\27`\233\325\332\360\234\331\256\220\235\244\265\220\236\271\220\220\237\204\227\220\310\tq\220\314\347K\20\315\251\27\220\316\242C\20\317\2224\20\320\202%\20\321r\26\20\321\266\226\0\322X\276\200\322\241O\20\322\3334\360\323c\33\220\324K#\220\3259\321 \325g\347\220\325\250s\0\326)\264\20\327,\32\20\330\t\226\20\331\2\301\220\331\351x\20\22\316\227\360\23MD\20\0243\372\220\25#\353\220\26\23\334\220\27\3\315\220\27\363\276\220\30\343\257\220\31\323\240\220\32\303\221\220\33\274\275\20\34\254\256\20\35\234\237\20\36\214\220\20\37|\201\20 lr\20!\\c\20\"LT\20#\206A\220?\233\34\220@f#\220A\2049\20BF\5\220Cd\33\20D%\347\220EC\375\20F\5\311\220G#\337\20G\356\346\20I\3\301\20I\316\310\20J\343\243\20K\256\252\20L\314\277\220M\216\214\20N\254\241\220Onn\20P\214\203\220QW\212\220Rle\220S7l\220TLG\220U\27N\220V,)\220V\3670\220X\25F\20X\327\22\220Y\365(\20Z\266\364\220[\325\n\20\\\240\21\20]\264\354\20^\177\363\20_\224\316\20`_\325\20a}\352\220b?\267\20c]\314\220d\37\231\20e=\256\220f\10\265\220g\35\220\220g\350\227\220h\375r\220i\310y\220j\335T\220k\250[\220l\306q\20m\210=\220n\246S\20oh\37\220p\2065\20qQ\206A\220\0\0\0\0?\233\34\220\0\0\0\0@f#\220\0\0\0\0A\2049\20\0\0\0\0BF\5\220\0\0\0\0Cd\33\20\0\0\0\0D%\347\220\0\0\0\0EC\375\20\0\0\0\0F\5\311\220\0\0\0\0G#\337\20\0\0\0\0G\356\346\20\0\0\0\0I\3\301\20\0\0\0\0I\316\310\20\0\0\0\0J\343\243\20\0\0\0\0K\256\252\20\0\0\0\0L\314\277\220\0\0\0\0M\216\214\20\0\0\0\0N\254\241\220\0\0\0\0Onn\20\0\0\0\0P\214\203\220\0\0\0\0QW\212\220\0\0\0\0Rle\220\0\0\0\0S7l\220\0\0\0\0TLG\220\0\0\0\0U\27N\220\0\0\0\0V,)\220\0\0\0\0V\3670\220\0\0\0\0X\25F\20\0\0\0\0X\327\22\220\0\0\0\0Y\365(\20\0\0\0\0Z\266\364\220\0\0\0\0[\325\n\20\0\0\0\0\\\240\21\20\0\0\0\0]\264\354\20\0\0\0\0^\177\363\20\0\0\0\0_\224\316\20\0\0\0\0`_\325\20\0\0\0\0a}\352\220\0\0\0\0b?\267\20\0\0\0\0c]\314\220\0\0\0\0d\37\231\20\0\0\0\0e=\256\220\0\0\0\0f\10\265\220\0\0\0\0g\35\220\220\0\0\0\0g\350\227\220\0\0\0\0h\375r\220\0\0\0\0i\310y\220\0\0\0\0j\335T\220\0\0\0\0k\250[\220\0\0\0\0l\306q\20\0\0\0\0m\210=\220\0\0\0\0n\246S\20\0\0\0\0oh\37\220\0\0\0\0p\2065\20\0\0\0\0qQ
[pid 12569] ) = 0
[pid 12569] gettimeofday({1424875003, 637261}, NULL) = 0
[pid 12569] stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=2309, ...}) = 0
[pid 12569] open("Log/messageLogger_2015-02-25T15-36-43.xml", O_WRONLY|O_CREAT|O_APPEND|O_LARGEFILE, 0666) = 9
[pid 12569] fstat64(9, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
[pid 12569] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb77cf000
[pid 12569] _llseek(9, 0, [0], SEEK_SET) = 0
[pid 12569] write(9, "Started: \n", 108) = 108
[pid 12569] fstat64(1, {st_mode=S_IFCHR|0600, st_rdev=makedev(136, 0), ...}) = 0
[pid 12569] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb77ce000
[pid 12569] write(1, "Wed Feb 25 15:36:43 2015 Started: \r\n", 36Wed Feb 25 15:36:43 2015 Started:
) = 36
[pid 12569] futex(0x9a7eb20, FUTEX_WAKE_PRIVATE, 1) = 0
[pid 12569] gettimeofday({1424875003, 641950}, NULL) = 0
[pid 12569] write(9, "Version: 2.7\n", 111) = 111
[pid 12569] write(1, "Wed Feb 25 15:36:43 2015 Version: 2.7\r\n", 39Wed Feb 25 15:36:43 2015 Version: 2.7
) = 39
[pid 12569] gettimeofday({1424875003, 644799}, NULL) = 0
[pid 12569] write(9, "Config path is: lcnpchk.xml\n", 126) = 126
[pid 12569] write(1, "Wed Feb 25 15:36:43 2015 Config path is: lcnpchk.xml\r\n", 54Wed Feb 25 15:36:43 2015 Config path is: lcnpchk.xml
) = 54
[pid 12569] gettimeofday({1424875003, 647312}, NULL) = 0
[pid 12569] write(9, "LogDir is: Log/\n", 114) = 114
[pid 12569] write(1, "Wed Feb 25 15:36:43 2015 LogDir is: Log/\r\n", 42Wed Feb 25 15:36:43 2015 LogDir is: Log/
) = 42
[pid 12569] open("lcnpchk.xml", O_RDONLY) = 10
[pid 12569] fstat64(10, {st_mode=S_IFREG|0644, st_size=1021, ...}) = 0
[pid 12569] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb77cd000
[pid 12569] _llseek(10, 0, [0], SEEK_SET) = 0
[pid 12569] read(10, "[Lizenzinformationen gelöscht]", 1021) = 1021
[pid 12569] _llseek(10, 1021, [1021], SEEK_SET) = 0
[pid 12569] close(10) = 0
[pid 12569] munmap(0xb77cd000, 4096) = 0
[pid 12569] socket(PF_INET, SOCK_DGRAM, IPPROTO_IP) = 10
[pid 12569] ioctl(10, SIOCGIFCONF, {64, {{"lo", {AF_INET, inet_addr("127.0.0.1")}}, {"eth0", {AF_INET, inet_addr("192.168.2.2")}}}}) = 0
[pid 12569] ioctl(10, SIOCGIFCONF, {96, {{"lo", {AF_INET, inet_addr("127.0.0.1")}}, {"eth0", {AF_INET, inet_addr("192.168.2.2")}}, {"tun0", {AF_INET, inet_addr("10.8.0.1")}}}}) = 0
[pid 12569] ioctl(10, SIOCGIFFLAGS, {ifr_name="lo", ifr_flags=IFF_UP|IFF_LOOPBACK|IFF_RUNNING}) = 0
[pid 12569] ioctl(10, SIOCGIFHWADDR, {ifr_name="lo", ifr_hwaddr=00:00:00:00:00:00}) = 0
[pid 12569] ioctl(10, SIOCGIFFLAGS, {ifr_name="eth0", ifr_flags=IFF_UP|IFF_BROADCAST|IFF_RUNNING|IFF_MULTICAST}) = 0
[pid 12569] ioctl(10, SIOCGIFHWADDR, {ifr_name="eth0", ifr_hwaddr=00:08:9b:cb:6a:03}) = 0
[pid 12569] ioctl(10, SIOCGIFFLAGS, {ifr_name="tun0", ifr_flags=IFF_UP|IFF_POINTOPOINT|IFF_RUNNING|IFF_NOARP|IFF_MULTICAST}) = 0
[pid 12569] ioctl(10, SIOCGIFHWADDR, {ifr_name="tun0", ifr_hwaddr=00:00:00:00:00:00}) = 0
[pid 12569] open("/usr/lib/i386-linux-gnu/gconv/gconv-modules.cache", O_RDONLY) = 10
[pid 12569] fstat64(10, {st_mode=S_IFREG|0644, st_size=26256, ...}) = 0
[pid 12569] mmap2(NULL, 26256, PROT_READ, MAP_SHARED, 10, 0) = 0xb77c7000
[pid 12569] futex(0x837a7a8, FUTEX_WAKE_PRIVATE, 2147483647) = 0
[pid 12569] open("/usr/lib/i386-linux-gnu/gconv/UTF-16.so", O_RDONLY|O_CLOEXEC) = 10
[pid 12569] read(10, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\4\0\0004\0\0\00001\0\0\0\0\0\0004\0 \0\7\0(\0\34\0\33\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\f#\0\0\f#\0\0\5\0\0\0\0\20\0\0\1\0\0\0\370.\0\0\370>\0\0\370>\0\0004\1\0\0008\1\0\0\6\0\0\0\0\20\0\0\2\0\0\0\4/\0\0\4?\0\0\4?\0\0\350\0\0\0\350\0\0\0\6\0\0\0\4\0\0\0\4\0\0\0\24\1\0\0\24\1\0\0\24\1\0\0D\0\0\0D\0\0\0\4\0\0\0\4\0\0\0P\345td\334 \0\0\334 \0\0\334 \0\0,\0\0\0,\0\0\0\4\0\0\0\4\0\0\0Q\345td\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\6\0\0\0\20\0\0\0R\345td\370.\0\0\370>\0\0\370>\0\0\10\1\0\0\10\1\0\0\4\0\0\0\1\0\0\0\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\27Y3R\363\337\202\26\t\265\207\302\341\211W\v\202J?\362\4\0\0\0\20\0\0\0\1\0\0\0GNU\0\0\0\0\0\2\0\0\0\6\0\0\0\30\0\0\0\3\0\0\0\v\0\0\0\1\0\0\0\5\0\0\0\f\20 \3\v\0\0\0\f\0\0\0\r\0\0\0c\f\177\0175\247R\200\231AH\227\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\20\0\0\0\0\0\0\0\0\0\0\0 \0\0\0\222\0\0\0\0\0\0\0\0\0\0\0\22\0\0\0F\0\0\0\0\0\0\0\0\0\0\0\"\0\0\0\201\0\0\0\0\0\0\0\0\0\0\0\22\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0 \0\0\0t\0\0\0\0\0\0\0\0\0\0\0\22\0\0\0\235\0\0\0\0\0\0\0\0\0\0\0", 512) = 512
[pid 12569] fstat64(10, {st_mode=S_IFREG|0644, st_size=13712, ...}) = 0
[pid 12569] mmap2(NULL, 16432, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 10, 0) = 0xb77c2000
[pid 12569] mmap2(0xb77c5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 10, 0x2000) = 0xb77c5000
[pid 12569] open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 10
[pid 12569] fstat64(10, {st_mode=S_IFREG|0644, st_size=96625, ...}) = 0
[pid 12569] mmap2(NULL, 96625, PROT_READ, MAP_PRIVATE, 10, 0) = 0xb77aa000
[pid 12569] access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
[pid 12569] open("/lib/i386-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 10
[pid 12569] read(10, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\233\1\0004\0\0\0\204\314\32\0\0\0\0\0004\0 \0\n\0(\0C\0B\0\6\0\0\0004\0\0\0004\0\0\0004\0\0\0@\1\0\0@\1\0\0\5\0\0\0\4\0\0\0\3\0\0\0t\300\26\0t\300\26\0t\300\26\0\23\0\0\0\23\0\0\0\4\0\0\0\1\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0H\202\32\0H\202\32\0\5\0\0\0\0\20\0\0\1\0\0\0\324\221\32\0\324\221\32\0\324\221\32\0\350,\0\0\250X\0\0\6\0\0\0\0\20\0\0\2\0\0\0\250\255\32\0\250\255\32\0\250\255\32\0\360\0\0\0\360\0\0\0\6\0\0\0\4\0\0\0\4\0\0\0t\1\0\0t\1\0\0t\1\0\0D\0\0\0D\0\0\0\4\0\0\0\4\0\0\0\7\0\0\0\324\221\32\0\324\221\32\0\324\221\32\0\10\0\0\0L\0\0\0\4\0\0\0\4\0\0\0P\345td\210\300\26\0\210\300\26\0\210\300\26\0\244t\0\0\244t\0\0\4\0\0\0\4\0\0\0Q\345td\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\6\0\0\0\20\0\0\0R\345td\324\221\32\0\324\221\32\0\324\221\32\0,\36\0\0,\36\0\0\4\0\0\0\1\0\0\0\4\0\0\0\24\0\0\0\3\0\0\0GNU\0v#\371\3157\231\256*T\223\332t\267\30\6\221\20#\203e\4\0\0\0\20\0\0\0\1\0\0\0GNU\0\0\0\0\0\2\0\0\0\6\0\0\0\30\0\0\0\363\3\0\0\n\0\0\0\0\2\0\0\16\0\0\0\2400\20D\200 \2\1\214\3\346\220AE\210\0\204\0\10\0E\200\0`\300\200\0\f\212\f\0\0010\0\10@2\10\256\4\210H6l\240\0260\0&\204\200\216\4\10B$", 512) = 512
[pid 12569] fstat64(10, {st_mode=S_IFREG|0755, st_size=1758972, ...}) = 0
[pid 12569] mmap2(NULL, 1763964, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 10, 0) = 0xb7451000
[pid 12569] mmap2(0xb75fa000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 10, 0x1a9000) = 0xb75fa000
[pid 12569] mmap2(0xb75fd000, 10876, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xb75fd000
[pid 12569] open("/lib/i386-linux-gnu/ld-linux.so.2", O_RDONLY|O_CLOEXEC) = 10
[pid 12569] read(10, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\20\0\0004\0\0\0T\t\2\0\0\0\0\0004\0 \0\7\0(\0\27\0\26\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\34\367\1\0\34\367\1\0\5\0\0\0\0\20\0\0\1\0\0\0\300\374\1\0\300\f\2\0\300\f\2\0\270\v\0\0x\f\0\0\6\0\0\0\0\20\0\0\2\0\0\0004\377\1\0004\17\2\0004\17\2\0\270\0\0\0\270\0\0\0\6\0\0\0\4\0\0\0\4\0\0\0\24\1\0\0\24\1\0\0\24\1\0\0$\0\0\0$\0\0\0\4\0\0\0\4\0\0\0P\345td\240\307\1\0\240\307\1\0\240\307\1\0\204\6\0\0\204\6\0\0\4\0\0\0\4\0\0\0Q\345td\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\6\0\0\0\20\0\0\0R\345td\300\374\1\0\300\f\2\0\300\f\2\0@\3\0\0@\3\0\0\4\0\0\0\1\0\0\0\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\22\365\275\315j\275_\244\21\325\3332j\374\354\346\4F!\304\21\0\0\0\35\0\0\0\2\0\0\0\33\0\0\0\31\0\0\0\16\0\0\0\4\0\0\0\5\0\0\0\7\0\0\0\25\0\0\0\0\0\0\0\0\0\0\0\21\0\0\0\t\0\0\0\6\0\0\0\10\0\0\0\23\0\0\0\17\0\0\0\n\0\0\0\0\0\0\0\26\0\0\0\0\0\0\0\0\0\0\0\22\0\0\0\32\0\0\0\0\0\0\0\3\0\0\0\34\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\v\0\0\0\0\0\0\0\0\0\0\0\24\0\0\0\0\0\0\0\27\0\0\0\f\0\0\0\20\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\1\0\0\0\30\0\0\0\r\0\0\0\0\0\0\0\0\0\0\0\21\0\0\0\1\0\0\0", 512) = 512
[pid 12569] fstat64(10, {st_mode=S_IFREG|0755, st_size=134380, ...}) = 0
[pid 12569] mmap2(NULL, 137528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 10, 0) = 0xb7788000
[pid 12569] mmap2(0xb77a8000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 10, 0x1f000) = 0xb77a8000
[pid 12569] mprotect(0xb77a8000, 4096, PROT_READ) = 0
[pid 12569] mprotect(0xb75fa000, 8192, PROT_READ) = 0
[pid 12569] mprotect(0xb77c5000, 4096, PROT_READ) = 0
[pid 12569] munmap(0xb77aa000, 96625) = 0
[pid 12569] mmap2(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7351000
[pid 12569] pipe([10, 11]) = 0
[pid 12569] ioctl(10, FIONBIO, [1]) = 0
[pid 12569] pipe([12, 13]) = 0
[pid 12569] ioctl(12, FIONBIO, [1]) = 0
[pid 12569] write(13, "\0", 1) = 1
[pid 12569] pipe([14, 15]) = 0
[pid 12569] ioctl(14, FIONBIO, [1]) = 0
[pid 12569] pipe([16, 17]) = 0
[pid 12569] ioctl(16, FIONBIO, [1]) = 0
[pid 12569] pipe([18, 19]) = 0
[pid 12569] ioctl(18, FIONBIO, [1]) = 0
[pid 12569] pipe([20, 21]) = 0
[pid 12569] ioctl(20, FIONBIO, [1]) = 0
[pid 12569] write(21, "\0", 1) = 1
[pid 12569] pipe([22, 23]) = 0
[pid 12569] ioctl(22, FIONBIO, [1]) = 0
[pid 12569] read(16, 0xbff6d2cf, 1) = -1 EAGAIN (Resource temporarily unavailable)
[pid 12569] mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0xb77ba000
[pid 12569] mprotect(0xb77ba000, 4096, PROT_NONE) = 0
[pid 12569] clone(Process 12572 attached
[pid 12572] set_robust_list(0xb77c1bb0, 12
[pid 12569] child_stack=0xb77c12a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb77c1ba8, {entry_number:6, base_addr:0xb77c1b40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb77c1ba8) = 12572
[pid 12572] ) = 0
[pid 12569] pipe(
[pid 12572] select(23, [12 14 16 18 22], NULL, NULL, NULL
[pid 12569] [24, 25]) = 0
[pid 12572] ) = 1 (in [12])
[pid 12569] ioctl(24, FIONBIO
[pid 12572] gettimeofday(
[pid 12572] {1424875003, 664804}, NULL) = 0
[pid 12569] write(25, "\0", 1
[pid 12572] socket(PF_INET, SOCK_STREAM, IPPROTO_TCP
[pid 12569] ) = 1
[pid 12572] ) = 26
[pid 12572] setsockopt(26, SOL_SOCKET, SO_REUSEADDR, [1], 4
[pid 12569] {1424875003, 665436}, NULL) = 0
[pid 12572] ) = 0
[pid 12569] socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP
[pid 12572] ioctl(26, FIONBIO
[pid 12569] ) = 27
[pid 12572] , [1]) = 0
[pid 12569] setsockopt(27, SOL_SOCKET, SO_REUSEADDR, [1], 4
[pid 12572] bind(26, {sa_family=AF_INET, sin_port=htons(4220), sin_addr=inet_addr("0.0.0.0")}, 16
[pid 12569] ) = 0
[pid 12572] ) = 0
[pid 12569] ioctl(27, FIONBIO
[pid 12572] listen(26, 32
[pid 12572] ) = 0
[pid 12569] setsockopt(27, SOL_SOCKET, SO_BROADCAST, [1], 4
[pid 12572] read(10,
[pid 12569] ) = 0
[pid 12572] 0xb77c0edf, 1) = -1 EAGAIN (Resource temporarily unavailable)
[pid 12569] bind(27, {sa_family=AF_INET, sin_port=htons(4220), sin_addr=inet_addr("0.0.0.0")}, 16
[pid 12572] mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0
[pid 12569] ) = 0
[pid 12572] ) = 0xb77b2000
[pid 12569] setsockopt(27, SOL_IP, IP_MULTICAST_TTL, "\377", 1
[pid 12572] mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0
[pid 12569] ) = 0
[pid 12572] ) = 0xb7151000
[pid 12569] setsockopt(27, SOL_IP, IP_ADD_MEMBERSHIP, "\352\5\6\7\0\0\0\0", 8
[pid 12572] munmap(0xb7151000, 716800
[pid 12569] ) = 0
[pid 12572] ) = 0
[pid 12569] read(24,
[pid 12572] munmap(0xb7300000, 331776
[pid 12572] ) = 0
[pid 12572] mprotect(0xb7200000, 135168, PROT_READ|PROT_WRITE
[pid 12569] ) = 0xb77aa000
[pid 12572] ) = 0
[pid 12569] mprotect(0xb77aa000, 4096, PROT_NONE
[pid 12572] mprotect(0xb77b2000, 4096, PROT_NONE
[pid 12569] ) = 0
[pid 12572] ) = 0
[pid 12569] clone(
[pid 12572] clone(Process 12573 attached
Process 12574 attached
[pid 12573] set_robust_list(0xb77b1bb0, 12
[pid 12574] set_robust_list(0xb77b9bb0, 12
[pid 12573] ) = 0
[pid 12574] ) = 0
[pid 12573] mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0
[pid 12574] mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0
[pid 12573] ) = 0xb7000000
[pid 12574] ) = 0xb6e00000
[pid 12573] munmap(0xb7100000, 1048576
[pid 12574] munmap(0xb6f00000, 1048576
[pid 12573] ) = 0
[pid 12574] ) = 0
[pid 12573] mprotect(0xb7000000, 143360, PROT_READ|PROT_WRITE
[pid 12574] mprotect(0xb6e00000, 135168, PROT_READ|PROT_WRITE
[pid 12573] ) = 0
[pid 12574] ) = 0
[pid 12573] select(28, [27], NULL, NULL, NULL
[pid 12574] select(27, [26], NULL, NULL, NULL
[pid 12572] child_stack=0xb77b92a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb77b9ba8, {entry_number:6, base_addr:0xb77b9b40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb77b9ba8) = 12574
[pid 12569] child_stack=0xb77b12a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb77b1ba8, {entry_number:6, base_addr:0xb77b1b40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb77b1ba8) = 12573
[pid 12572] read(12,
[pid 12569] pipe(
[pid 12572] "\0", 1) = 1
[pid 12569] [28, 29]) = 0
[pid 12569] ioctl(28, FIONBIO, [1]) = 0
[pid 12569] read(28, 0xbff6d4bf, 1) = -1 EAGAIN (Resource temporarily unavailable)
[pid 12569] mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0xb7780000
[pid 12569] mprotect(0xb7780000, 4096, PROT_NONE) = 0
[pid 12569] clone(Process 12575 attached
[pid 12575] set_robust_list(0xb7787bb0, 12
[pid 12569] child_stack=0xb77872a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb7787ba8, {entry_number:6, base_addr:0xb7787b40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb7787ba8) = 12575
[pid 12575] ) = 0
[pid 12569] nanosleep({0, 100000000},
[pid 12575] pipe([30, 31]) = 0
[pid 12575] ioctl(30, FIONBIO, [1]) = 0
[pid 12575] mmap2(0xb6f00000, 1048576, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0xb6f00000
[pid 12575] mprotect(0xb6f00000, 135168, PROT_READ|PROT_WRITE) = 0
[pid 12575] open("/dev/urandom", O_RDONLY|O_NOCTTY|O_NONBLOCK) = 32
[pid 12575] fstat64(32, {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 9), ...}) = 0
[pid 12575] poll([{fd=32, events=POLLIN}], 1, 10) = 1 ([{fd=32, revents=POLLIN}])
[pid 12575] read(32, "\313z\26\7\35R\205R]\342\352\220^\273\320=\234\351\223\315\376\00578 \217\346\306\"w\v\323", 32) = 32
[pid 12575] close(32) = 0
[pid 12575] getuid32() = 0
[pid 12575] time(NULL) = 1424875003
[pid 12575] pipe([32, 33]) = 0
[pid 12575] ioctl(32, FIONBIO, [1]) = 0
[pid 12575] pipe([34, 35]) = 0
[pid 12575] ioctl(34, FIONBIO, [1]) = 0
[pid 12575] pipe([36, 37]) = 0
[pid 12575] ioctl(36, FIONBIO, [1]) = 0
[pid 12575] pipe([38, 39]) = 0
[pid 12575] ioctl(38, FIONBIO, [1]) = 0
[pid 12575] read(32, 0xb7786e0f, 1) = -1 EAGAIN (Resource temporarily unavailable)
[pid 12575] mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0xb7778000
[pid 12575] mprotect(0xb7778000, 4096, PROT_NONE) = 0
[pid 12575] clone(Process 12576 attached
[pid 12576] set_robust_list(0xb777fbb0, 12
[pid 12575] child_stack=0xb777f2a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb777fba8, {entry_number:6, base_addr:0xb777fb40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb777fba8) = 12576
[pid 12576] ) = 0
[pid 12575] nanosleep({0, 100000000},
[pid 12576] select(33, [32], NULL, NULL, {0, 0}) = 0 (Timeout)
[pid 12576] gettimeofday({1424875003, 678985}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 679144}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 679295}, NULL) = 0
[pid 12576] open("/dev/ttyUSB0", O_RDWR|O_NOCTTY|O_NONBLOCK) = 40
[pid 12576] ioctl(40, TIOCMGET, [TIOCM_DTR|TIOCM_RTS|TIOCM_DSR]) = 0
[pid 12576] ioctl(40, SNDCTL_TMR_TIMEBASE or SNDRV_TIMER_IOCTL_NEXT_DEVICE or TCGETS, {B9600 -opost -isig -icanon -echo ...}) = 0
[pid 12576] ioctl(40, FIONBIO, [1]) = 0
[pid 12576] ioctl(40, TCFLSH, 0) = 0
[pid 12576] ioctl(40, SNDCTL_TMR_START or SNDRV_TIMER_IOCTL_TREAD or TCSETS, {B9600 -opost -isig -icanon -echo ...}) = 0
[pid 12576] ioctl(40, TIOCMBIS, [TIOCM_DTR]) = 0
[pid 12576] ioctl(40, TIOCMBIC, [TIOCM_RTS]) = 0
[pid 12576] nanosleep({0, 1000000}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 683622}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 683763}, NULL) = 0
[pid 12576] mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0xb6c00000
[pid 12576] munmap(0xb6d00000, 1048576) = 0
[pid 12576] mprotect(0xb6c00000, 135168, PROT_READ|PROT_WRITE) = 0
[pid 12576] gettimeofday({1424875003, 684377}, NULL) = 0
[pid 12576] select(41, NULL, [40], NULL, {0, 100000}) = 1 (out [40], left {0, 99989})
[pid 12576] ioctl(40, TIOCMGET, [TIOCM_DTR|TIOCM_DSR]) = 0
[pid 12576] ioctl(40, TIOCGICOUNT, 0xb777ef84) = 0
[pid 12576] nanosleep({0, 8000000}, NULL) = 0
[pid 12576] ioctl(40, TIOCGICOUNT, 0xb777efd4) = 0
[pid 12576] ioctl(40, TIOCMBIS, [TIOCM_RTS]) = 0
[pid 12576] write(40, " \0\200\0\4\0", 6) = 6
[pid 12576] nanosleep({0, 7240000}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 702556}, NULL) = 0
[pid 12576] select(41, [40], NULL, NULL, {0, 10000}) = 1 (in [40], left {0, 9991})
[pid 12576] read(40, "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0 \0\200\0\4\0", 4096) = 29
[pid 12576] gettimeofday({1424875003, 703093}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 703252}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 703424}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 703563}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 703713}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 703854}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 704018}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 704167}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 704312}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 704452}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 704754}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 704893}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 705059}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 705199}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 705336}, NULL) = 0
[pid 12576] write(31, "\0", 1) = 1
[pid 12576] write(35, "\0", 1) = 1
[pid 12576] select(41, [40], NULL, NULL, {0, 10000}) = 0 (Timeout)
[pid 12576] gettimeofday({1424875003, 716500}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 716649}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 716794}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 727457}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 727638}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 727787}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 738386}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 738566}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 738713}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 749321}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 749500}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 749648}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 760207}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 760360}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 760521}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 771110}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 771277}, NULL) = 0
[pid 12576] gettimeofday({1424875003, 771426}, NULL) = 0
[pid 12569] NULL) = 0
[pid 12575] NULL) = 0
[pid 12575] read(36, 0xb7786e0f, 1) = -1 EAGAIN (Resource temporarily unavailable)
[pid 12575] mmap2(NULL, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0xb7770000
[pid 12575] mprotect(0xb7770000, 4096, PROT_NONE) = 0
[pid 12575] clone(Process 12577 attached
[pid 12577] set_robust_list(0xb7777bb0, 12
[pid 12575] child_stack=0xb77772a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0xb7777ba8, {entry_number:6, base_addr:0xb7777b40, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0xb7777ba8) = 12577
[pid 12577] ) = 0
[pid 12575] pipe(
[pid 12577] mmap2(0xb6d00000, 1048576, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0
[pid 12575] [41, 42]) = 0
[pid 12577] ) = 0xb6d00000
[pid 12575] ioctl(41, FIONBIO
[pid 12577] mprotect(0xb6d00000, 135168, PROT_READ|PROT_WRITE
[pid 12575] , [1]) = 0
[pid 12577] ) = 0
[pid 12575] pipe(
[pid 12577] socket(PF_INET, SOCK_STREAM, IPPROTO_TCP
[pid 12575] [43, 44]) = 0
[pid 12577] ) = 45
[pid 12575] ioctl(43, FIONBIO
[pid 12577] setsockopt(45, SOL_SOCKET, SO_REUSEADDR, [1], 4
[pid 12577] ) = 0
[pid 12575] socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP
[pid 12577] ioctl(45, FIONBIO
[pid 12575] ) = 46
[pid 12577] , [1]) = 0
[pid 12575] setsockopt(46, SOL_SOCKET, SO_REUSEADDR, [1], 4
[pid 12577] bind(45, {sa_family=AF_INET, sin_port=htons(4114), sin_addr=inet_addr("0.0.0.0")}, 16
[pid 12575] ) = 0
[pid 12577] ) = 0
[pid 12575] ioctl(46, FIONBIO
[pid 12577] listen(45, 5
[pid 12577] ) = 0
[pid 12576] ) = 0 (Timeout)
[pid 12577] select(37, [36], NULL, NULL, {0, 0}
[pid 12577] ) = 0 (Timeout)
[pid 12576] {1424875003, 782223}, NULL) = 0
[pid 12577] open("/dev/urandom", O_RDONLY|O_NOCTTY|O_NONBLOCK
[pid 12577] ) = 47
[pid 12576] {1424875003, 782513}, NULL) = 0
[pid 12577] fstat64(47,
[pid 12577] {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 9), ...}) = 0
[pid 12576] {1424875003, 782752}, NULL) = 0
[pid 12577] poll([{fd=47, events=POLLIN}], 1, 10
[pid 12577] ) = 1 ([{fd=47, revents=POLLIN}])
[pid 12577] read(47,
[pid 12577] "J{\370G\376\21\37\24\350N\213xp\3205\250D\3\356\1\5%\343\331I\4%\265j\26\2523", 32) = 32
[pid 12575] setsockopt(46, SOL_SOCKET, SO_BROADCAST, [1], 4
[pid 12577] close(47
[pid 12575] ) = 0
[pid 12577] ) = 0
[pid 12575] time(
[pid 12577] getuid32(
[pid 12575] NULL) = 1424875003
[pid 12577] ) = 0
[pid 12575] gettimeofday(
[pid 12577] time(
[pid 12575] {1424875003, 783977}, {4294967236, 0}) = 0
[pid 12577] NULL) = 1424875003
[pid 12575] select(47, NULL, [46], NULL, {5, 0}
[pid 12577] pipe(
[pid 12575] ) = 1 (out [46], left {4, 999992})
[pid 12577] [47, 48]) = 0
[pid 12575] open("/etc/resolv.conf", O_RDONLY|O_CLOEXEC
[pid 12577] ioctl(47, FIONBIO
[pid 12575] ) = 49
[pid 12575] fstat64(49,
[pid 12577] select(46, [45], NULL, NULL, {0, 10000}
[pid 12575] {st_mode=S_IFREG|0644, st_size=198, ...}) = 0
[pid 12575] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb776f000
[pid 12575] read(49, "# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)\n# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN\nnameserver 127.0.0.1\nsearch xxxxxxx.com\n", 4096) = 198
[pid 12575] read(49, "", 4096) = 0
[pid 12575] close(49) = 0
[pid 12575] munmap(0xb776f000, 4096) = 0
[pid 12575] socket(PF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0) = 49
[pid 12575] connect(49, {sa_family=AF_LOCAL, sun_path="/var/run/nscd/socket"}, 110) = -1 ENOENT (No such file or directory)
[pid 12575] open("/etc/nsswitch.conf", O_RDONLY|O_CLOEXEC) = 49
[pid 12575] fstat64(49, {st_mode=S_IFREG|0644, st_size=507, ...}) = 0
[pid 12575] read(49, "# /etc/nsswitch.conf\n#\n# Example configuration of GNU Name Service Switch functionality.\n# If you have the `glibc-doc-reference' and `info' packages installed, try:\n# `info libc \"Name Service Switch\"' for information about this file.\n\npasswd: compat\ngroup: compat\nshadow: compat\n\nhosts: files mdns4_minimal [NOTFOUND=return] dns\nnetworks: files\n\nprotocols: db files\nservices: db files\nethers: db files\nrpc: db files\n\nnetgroup: nis\n", 4096) = 507
[pid 12575] open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 49
[pid 12575] fstat64(49, {st_mode=S_IFREG|0644, st_size=96625, ...}) = 0
[pid 12575] mmap2(NULL, 96625, PROT_READ, MAP_PRIVATE, 49, 0) = 0xb7758000
[pid 12575] access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
[pid 12575] open("/lib/i386-linux-gnu/libnss_files.so.2", O_RDONLY|O_CLOEXEC) = 49
[pid 12575] read(49, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\32\0\0004\0\0\0,\262\0\0\0\0\0\0004\0 \0\t\0(\0\36\0\35\0\6\0\0\0004\0\0\0004\0\0\0004\0\0\0 \1\0\0 \1\0\0\5\0\0\0\4\0\0\0\3\0\0\0\221\210\0\0\221\210\0\0\221\210\0\0\23\0\0\0\23\0\0\0\4\0\0\0\1\0\0\0\1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\240\245\0\0\240\245\0\0\5\0\0\0\0\20\0\0\1\0\0\0\304\256\0\0\304\276\0\0\304\276\0\0@\2\0\0\20\5\0\0\6\0\0\0\0\20\0\0\2\0\0\0\320\256\0\0\320\276\0\0\320\276\0\0\10\1\0\0\10\1\0\0\6\0\0\0\4\0\0\0\4\0\0\0T\1\0\0T\1\0\0T\1\0\0D\0\0\0D\0\0\0\4\0\0\0\4\0\0\0P\345td\244\210\0\0\244\210\0\0\244\210\0\0\364\2\0\0\364\2\0\0\4\0\0\0\4\0\0\0Q\345td\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\6\0\0\0\20\0\0\0R\345td\304\256\0\0\304\276\0\0\304\276\0\0<\1\0\0<\1\0\0\4\0\0\0\1\0\0\0\4\0\0\0\24\0\0\0\3\0\0\0GNU\0\257}\302\206!bi\356\331\210\322N]\324\271H\25\227\374y\4\0\0\0\20\0\0\0\1\0\0\0GNU\0\0\0\0\0\2\0\0\0\6\0\0\0\30\0\0\0k\0\0\0/\0\0\0\20\0\0\0\t\0\0\0\"F\340\24\260\241\245\1\31\10\3000\203\6\212\10\0\200\322@]\1(\nx\10 \"\220\200\30,\7\3\205\24)!\22<\0\24\0\31\0\0\2\2\210@\0\200@0\210\201@@\200\0\302\0\6\300/\0\0\0000\0\0\0\0\0\0\0001\0\0\0002\0\0\0003\0\0\0", 512) = 512
[pid 12575] fstat64(49, {st_mode=S_IFREG|0644, st_size=46812, ...}) = 0
[pid 12575] mmap2(NULL, 50132, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 49, 0) = 0xb774b000
[pid 12575] mmap2(0xb7756000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 49, 0xa000) = 0xb7756000
[pid 12575] mprotect(0xb7756000, 4096, PROT_READ) = 0
[pid 12575] munmap(0xb7758000, 96625) = 0
[pid 12575] open("/etc/host.conf", O_RDONLY|O_CLOEXEC) = 49
[pid 12575] fstat64(49, {st_mode=S_IFREG|0644, st_size=92, ...}) = 0
[pid 12575] read(49, "# The \"order\" line is only used by old versions of the C library.\norder hosts,bind\nmulti on\n", 4096) = 92
[pid 12575] futex(0x837b544, FUTEX_WAKE_PRIVATE, 2147483647) = 0
[pid 12575] mmap2(NULL, 2097152, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0) = 0xb6a00000
[pid 12575] munmap(0xb6b00000, 1048576) = 0
[pid 12575] mprotect(0xb6a00000, 135168, PROT_READ|PROT_WRITE) = 0
[pid 12575] open("/etc/hosts", O_RDONLY|O_CLOEXEC) = 49
[pid 12575] fstat64(49, {st_mode=S_IFREG|0644, st_size=386, ...}) = 0
[pid 12575] read(49, "127.0.0.1\tlocalhost\n192.168.2.2\tserver\n192.168.2.2\twww.xxxxxxx.com\n192.168.2.2\txxxxxxx.com\n192.168.2.2\tdav.xxxxxx.com\n192.168.2.2\twww.xxxxxxx.de\n192.168.2.2\txxxxxxx.de\n\n# The following lines are desirable for IPv6 capable hosts\n::1 ip6-localhost ip6-loopback\nfe00::0 ip6-localnet\nff00::0 ip6-mcastprefix\nff02::1 ip6-allnodes\nff02::2 ip6-allrouters\n", 4096) = 386
[pid 12575] --- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x63} ---
[pid 12573] +++ killed by SIGSEGV (core dumped) +++
[pid 12572] +++ killed by SIGSEGV (core dumped) +++
[pid 12574] +++ killed by SIGSEGV (core dumped) +++
[pid 12571] +++ killed by SIGSEGV (core dumped) +++
[pid 12570] +++ killed by SIGSEGV (core dumped) +++
[pid 12576] +++ killed by SIGSEGV (core dumped) +++
[pid 12575] +++ killed by SIGSEGV (core dumped) +++
[pid 12577] +++ killed by SIGSEGV (core dumped) +++
