die Visu gibt fir folgenden Fehlermeldungen aus:
1 X Mittwoch, 7. August 2013 18:45:33 request for >M000011.A1DI000004 failed: unknown error (LinHK not running or unreachable, incompatible browser?)
2 X Mittwoch, 7. August 2013 18:45:38 request for pcklog failed: unknown error (LinHK not running or unreachable, incompatible browser?)
Ich konnte kurz nach dem Start der Visu das Licht im Raum steuern, bekam aber kein visulelles Feedback. Nach geraumer Zeit geht die Visu in den Offline-Mode und hat keine Module gefunden.
[20130807 18:46:40.871320] [info] LinHK 0.151.0
[20130807 18:46:40.872177] [info] Copyright (c) 2008-2013 Niko Baric
[20130807 18:46:40.874064] [info] running on Linux fritz.fonwlan.box 2.6.32.41 #2 Mon Jan 14 13:09:57 CET 2013 mips (Fritz_Box_7270_16 54.05.50)
[20130807 18:46:40.874476] [info] system uptime: 0 days 0:05
[20130807 18:46:40.874872] [info] used LinHK starter: ok
[20130807 18:46:40.876972] [info] current working directory: /var/media/ftp/TS128MJFLASHA-01/linhk
[20130807 18:46:40.877466] [info] start parameters: -d /var/tmp/ttyUSB0 -s fritz.box -H 43 -O messwerte.json -A ./.user
[20130807 18:46:40.899493] [info] licensee: xxxxxxxxxx yyyyyyyyy
[20130807 18:46:40.903445] [notice] skipping insecure access rule for user `dosenbrot'
[20130807 18:46:40.909694] [info] moving state file messwerte.json to messwerte-1375894000.json
[20130807 18:46:40.919733] [info] Connected to the serial bus via `/var/tmp/ttyUSB0'
[20130807 18:46:40.920519] [info] listening for incoming PCK requests on 4114 (IPv6)
[20130807 18:46:40.921143] [info] listening for incoming PCK requests on 4114
[20130807 18:46:40.921745] [info] listening for incoming HTTP requests on 8000 (IPv6)
[20130807 18:46:40.922276] [info] listening for incoming HTTP requests on 8000
[20130807 18:46:40.923310] [info] listening for incoming HTTPS requests on 8443 (IPv6)
[20130807 18:46:40.923868] [info] listening for incoming HTTPS requests on 8443
[20130807 18:46:40.941505] [notice] a6cec2b6bc3bff8d2b1a
[20130807 18:46:40.942172] [notice] 0331f425fb74420756a2
[20130807 18:46:40.942827] [error] /var/tmp/ttyUSB0: read zero bytes (2 times)
[20130807 18:46:40.943305] [error] /var/tmp/ttyUSB0: read zero bytes (3 times)
[20130807 18:46:40.943746] [error] /var/tmp/ttyUSB0: read zero bytes (4 times)
[20130807 18:46:40.944185] [error] /var/tmp/ttyUSB0: read zero bytes (5 times)
[20130807 18:46:40.944623] [error] /var/tmp/ttyUSB0: read zero bytes (6 times)
[20130807 18:46:40.956512] [error] /var/tmp/ttyUSB0: read zero bytes (7 times)
[20130807 18:46:40.957377] [error] /var/tmp/ttyUSB0: read zero bytes (8 times)
[20130807 18:46:40.957829] [error] /var/tmp/ttyUSB0: read zero bytes (9 times)
Für Ideen bin ich offen ...
Danke und bis denne
Stef
