Hello Filip,
can you give me a sample of the syntax (notation) of the condition in events? Is the attached sample correct? I have try many possibilities, but it does not works.
Thanks for your help in advance.
Skript
#12 RE: Skript
For events you should use full channel name and Lua operators.
Any channel value will be automatically converted from string to number, if it is possible.
For example:
The best way to see what can be used as condition is to telnet to port 4224 and send ?[ENTER] - all current channel values will be shown.
For example:
VAR.ala_og == 1
MEM.season == 'summer'
LCN.relay.0.20.1 == 1 and LCN.output.0.30.1 <= 1200
#13 RE: Skript
Thank you.
Is it possible to make a counter - variable in the channel, like C.VAR.alarm=VAR.alarm+1 ?
Is in this case CHANNEL name=C.VAR.alarm value=VAR.alarm+1 the correct syntax?
#14 RE: Skript
To make a counter you need to do it in Logic:
And then use this in Events/Timers as Channel command
ctr = use "VAR.counter"
function ctr:increment()
ctr:set(ctr.value + 1)
end
Value: ctr:increment()
Mitglieder in diesem Forum: 0 Mitglieder und 39 Gäste
