gibst du bitte bescheid wenn sich da etwas zum positiven entwickelt ?
Danke Matthias
Air Display
- Hat sich bedankt: 19 Mal
#12 RE: Air Display
Hallo Matthias,
habe bis jetzt noch keine Info von Filip bekommen.
#13 RE: Air Display
Hello, it will take few more weeks, but there will be new AirDisplay soon, version 1.8.0.
Within a week or two it will be possible to do some preliminary alpha version testing. Most important change is introduction of DEAP server, which should enable remote operation after pairing as with Remote. We will need to test it with multiple routers etc to make sure it works properly, as well as to make sure all configuration loading bugs were found.
#14 RE: Air Display
Filip,
i just updated Adobe Air and installed Air Display 1.8 which has been published recently. Furthermore i updated the firmware of my base. However i don't get Air Display running, for whatever reason it stuck right after i fire it up. I don't even get to the point to enter user/pw. I tried to get it running on an Win7 Professional machine so basically nothing special, right?
Any feedback is much appreciated.
cya
Stefan
cya
Stefan
#15 RE: Air Display
Will check. Please note that version 1.8 will ask for pairing code, just as for Remote. No license will be used though.
You can try to re-save the Display tab in Configurator, this will force data refresh in AirDisplay.
#17 RE: Air Display
Soweit ich mich erinnere, musst du keinen Code eingeben. Du benötigst noch eine Frei Lizenz und dann greift sich das Air Display beim ersten Öffnen die Lizenz.
#18 RE: Air Display
Hi Piotr
I just updated Air today including Adobe Air to newest version. I could pair air display, but will not get beyond the Domiq start page.
Is air display working at the moment?
Any hints?
Regards Florian
Any hints?
Regards Florian
#19 RE: Air Display
Naja leider etwas extrem unzuverlässig der Support von diesem Herrn Filip. Es geht nach wie vor nicht. :thumbdown:
#20 RE: Air Display
[zitat]... leider etwas extrem unzuverlässig ...[/zitat]
Das sehe ich aber gänzlich anders.
Allerdings: ich kenne bislang niemanden der das AirDisplay mit Erfolg betreibt. Gibt es da jemanden?
Ansonsten wäre für mich nach der deutschen Version des Handbuchs (:thumbup: ) mal ein "How to" für AirDisplay dran
Grüße, Uwe - der dem Herrn Filip aber nicht seine Prioritäten durcheinanderbringen will![Überglücklich :D](./images/smilies/icon_e_biggrin.gif)
![Zwinkern ;)](./images/smilies/icon_e_wink.gif)
