Zugang mit LCN-PRO über Domiq schlecht
#21 RE: Zugang mit LCN-PRO über Domiq schlecht
@xtof do you have any LinHK modules in your installation?
#22 RE: Zugang mit LCN-PRO über Domiq schlecht
Hello,
no, I just have Issendorf, Domiq Base and some DIY components.
I tried to type the commands like
list
tcp
netstat tcp
mall
manually in hyperterminal but they were overwritten immediately by the variable actualizations of my energy counter.
Do I need LinHK to get the diagnosis information you requested? Or do you mean that remote debugging for LUA is available with LinHK only.
Best regards
Xtof
list
tcp
netstat tcp
mall
Best regards
Xtof
#23 RE: Zugang mit LCN-PRO über Domiq schlecht
You need to type those commands in standard telnet connection, not to port 4224. But it's not important right now. How exactly your scanning problem looked like? Base doesn't scan any module at all?
I asked about LinHK because we found some issues with reading them in Pro (even using LCN-PK) and I thought it might be the cause, but we think we found solution elsewhere:)
