#1 access control with domiq
Verfasst: Mo 7. Nov 2011, 09:55
while evaluating, if domiq might be the right control system for a new installation, can you do access control?
Do you receive the UTL codes and can evaluate them (more than the maximum of 8 keyes in an UPP module)
Regards Florian
#2 RE: access control with domiq
Verfasst: Mo 7. Nov 2011, 10:32
von DOMIQ
Hello Florian,
if you make modules sent transponder codes to the LCN bus, those will appear as below:
If you do some rules in Events tab, you could use that to implement access control system.
We would be happy to create tutorial together with you how exactly that should be implemented (we don't have transponders at our office and we like to create tutorials based on real needs).
#3 RE: access control with domiq
Verfasst: Di 8. Nov 2011, 00:49
Wir probieren das in meinem Koffer, Florian.
Ich muss den nur erst noch mal wieder aufbauen ...
Grüße, Uwe - ... will be happy together ... :w00t:
#4 RE: access control with domiq
Verfasst: Fr 2. Dez 2011, 10:38
von lcn_iberica
It would be great that DOMIQ can just recieve transponder code and manage it directly, to have a more powerful access control than the one in LCN modules (just 16 codes, no access rights, etc.).
Maybe an Access Control tab can be implemented in the next version of Base firmware??
