#1 Exclusive Layer in the display mode
Verfasst: So 12. Feb 2012, 22:09
				Hi Filip,
is it possible in the display mode, to set in one screen an exclusive layer?
For example:
In every room in the ground floor is a switch that creat a layer in one area on the screen.
When I press the switch at the guest room than is the layer of the guest room visible. If I then press the switch for the hallway, is the layer of the hallway over the layer of the guest room. Is it possible, to close the layer of the guest room with the opening of the layer of the hallway with the switch of the hallway?
[img]2[/img]
For example:
[img]2[/img]
