#1 Update: System 3.0.0.0
Verfasst: Mo 30. Jan 2023, 14:27
Today we published an update, that we have been working on for several months. We are proud that the result months of work is finally released to the public use. This update brings several fundamental changes that translate into a significant growth of system performance and increase of disk space available for users. We have also added new functionalities to extend the capabilities of our system.
These are the 5 major changes:
1. Switched to Lua 5.4 from Lua 5.1. The Lua programming language is the main language used to DOMIQ/Base’s operating system. This migration translates into:
1.1 Faster code execution - our tests showed 50-100% performance boost!
1.2 Decreased RAM usage.
1.3 Reducing the size of the operating system by approximately 25%.
2. New memory allocator - this significantly reduces RAM fragmentation.
3. Completely new web server - the Configurator now runs much faster.
4. Rebuilt handling of Remote for iOS - much better responsivness and blazing fast reloading of configuration.
5.Added GZIP compression for system configuration files. This change results in:
5.1. 3-4x faster loading of configuration in Remote on iOS (ver. 1.14 required) and in the Configurator.
5.2. 3-4x less required disk space to save configuration files (in case of a fairly typical system configuration). The bigger the configuration files, the bigger is the space savings.
Full list of changes available here: https://domiq.eu/news/update_system_3.0.0.03
