SONOS Integration
#1 SONOS Integration
Beitragvon LCNNoob » Fr 12. Mai 2023, 07:00
Hello Team Domiq,
since last Update of SONOS app (Software) I can't see the variables UAV.title and UAV.album in the status TAB of configurator or REMOTE app. Other UAV variables are shown and updated. So UPNP seems to work. Do you know if SONOS changeg their internal names of some variables?
Thanks
#2 Re: SONOS Integration
Beitragvon LCNNoob » Sa 13. Mai 2023, 16:34
Hello all,
seems to be a problem after update of Router Firmware when router is startet new. There maybe is an problem of synchronisation between router and DOMIQ. Switching UPNP mode ON/ OFF in DOMIQ and restart of DOMIQ all is OK again.
I will have a view on this.
#3 Re: SONOS Integration
Beitragvon LCNNoob » Do 10. Aug 2023, 14:36
Hello again,
problem still there. After restart of DOMIQ there is no update of UPNP updates between DOMIQ and SONOS. Even after restarting Fritz.Box and and Server DNS/ DHP there is no update shown of SONOS changes in Remote.
The commands from Remote to control SONOS are working. Means I can start/ stop playing, rise or lower volume. But in Remote you do not see for example PLAYING. Instead of the SONOS states for URI/ Title/ Volume and so on, only value 0 in Remote is shown.
Following actions were taken:
-- Restarting Servers
-- Restarting Router
-- Restarting DOMIQ (including change of UPNP settings in TAB settings)
-- Deleting Cache on mobile (Android 9.x)
All actions were taken in different order with no success
UPNP states are not shown in DOMIQ TAB. No variable names are created after restart exept VOLUME. Sometimes it works again after somes days. (No changes and restarts are performed). But since last restart od DOMIQ no UPNP update was processed.
Was there a change since last update of DOMIQ or has it someting to do with the correction of the browser bug you corrected
Thx for an answer on this serious issue.
DOMIQ-Support
#4 Re: SONOS Integration
Beitragvon DOMIQ-Support » Mi 6. Sep 2023, 11:06
We haven't changed anything lately, so it's probably related to changes in the SONOS itself. Could you provide us the logs from the Base module booting?
#5 Re: SONOS Integration
Beitragvon LCNNoob » Mi 6. Sep 2023, 16:54
Hi Team,
yesterday AVM provided an security update for Fritz 7590. After installation and restart of fritz.box the SONOS within Remote doesn't work at all. I just unselect UPNP in Domiq Configurator and reboot Domiq. Thenafter I selected UPNP again and restartet Domiq. SONOS integration was enabled and worked.
I can send you the LOGS the next time when the issue occurs. Where can I find the boot logs of Domiq module?
Thanks for you help.
DOMIQ-Support
#6 Re: SONOS Integration
Beitragvon DOMIQ-Support » Di 3. Okt 2023, 15:02
To get logs run the Discover app and then 2x click on Base's IP address - the logs window will appear. After that, please reboot your module and wait for about 5 minutes so logs can gather.
