Makros in Base / Lua
Status: Online
#1 Makros in Base / Lua
Filip erwähnte einmal Makros. Wie bindet man denn Makros ins Base ein, ist das unter Logic oder als Event oder ...?
DOMIQ
#2 RE: Makros in Base / Lua
Beitrag von DOMIQ »
Basically any function in Logic can be called from Event, or Display. For example:
function alloff()
  command("C.LCN.output.0.20.1",0)
  command("C.LCN.output.0.20.2",0)
end
Then in Event you can add such channel:
C.LOGIC=alloff()
or you can add Switch to the Display and put following into command field:
LOGIC=alloff()
Example is not that good, as it would make more sense to do above with Events, but you can make more functions, more complicated functions etc
You can also pass parameters (possibly "extracted" with patters in Events). We will soon publish "Base to Base linking" tutorial, that will have extensive examples of more advanced Events usage.
KlausM
#3 RE: Makros in Base / Lua
Beitrag von KlausM »
Hi
Frage:
wie lautet der syntax wenn ich mit rampe schalten will? also so:
C.LCN.output.0.20.2=30;ramp:10
nur mit dem command befehl direkt aus dem lua logik script
command("C.LCN.output.0.20.2",80) <-Rampe???
thx
klaus
Status: Online
#4 RE: Makros in Base / Lua
command("C.LCN.output.0.20.2",80;ramp:10)
