Sende Taste an Base
koboldo
Hat sich bedankt: 7 Mal
#11 RE: Sende Taste an Base
Beitragvon koboldo » Mo 9. Dez 2013, 13:32
Hello Piotr,
the old syntax works....:thumbup:
The problem makes the new syntax...
If set in the Pro from module 5 the sendkey command to the Base with a5 hit....
And under events in the base wrote
E.LCN.key.0.5.A5
hit
It doesn´t work ....
If I go over the thresholds and do the sendkeys when a threshold is reached, it works.....:confused: :confused: :confused:
DOMIQ-Support
#12 RE: Sende Taste an Base
Beitragvon DOMIQ-Support » Mo 9. Dez 2013, 13:39
New syntax doesn't make any problem. If you test it from the LCN-Pro then the send-key command will be seen by Base as a command sent from LCN-Pro, not from LCN module. But try (just for testing) to bind send-key command to any phisical key and then press this key. Then you will see that the event actually works:)
koboldo
#13 RE: Sende Taste an Base
Beitragvon koboldo » Mo 9. Dez 2013, 14:23
That is what I did the whole evening :mad:
I will check again and then I will make some screenshots....
DOMIQ-Support
#14 RE: Sende Taste an Base
Beitragvon DOMIQ-Support » Mo 9. Dez 2013, 14:30
Obviously you did something wrong. I tested it and I'm sure it works properly.
Wowbagger
#15 RE: Sende Taste an Base
Beitragvon Wowbagger » Mo 9. Dez 2013, 17:10
Funktioniert bei mir ebenfalls einwandfrei, sowohl die alte als auch die neue Syntax...
Kannst Du mal einen Mitschnitt des Pro Monitors posten?
koboldo
#16 RE: Sende Taste an Base
Beitragvon koboldo » Di 10. Dez 2013, 09:41
Funktioniert jetzt :lol:
Habe allerdings vorher das Base von 1.8.1.1 auf 1.8.2.0 geupdated....:-/
Vielleicht lag es daran....
