RANDOM
Franky
#1 RANDOM
Beitrag von Franky »
Hi Filip,
is it possible, to use in the logic a random function like:
Zufall = math.random()
DOMIQ
#2 RE: RANDOM
Beitrag von DOMIQ »
Yes, random will return random value between 0 and 1. So you should use it like:
if math.random() > 0.8 then
  -- do something with 80% probability
end
#3 RE: RANDOM
This should give you a 20% probability, ;)
or it should be
if math.random() < 0.8 then
Regards Florian
DOMIQ
#4 RE: RANDOM
Beitrag von DOMIQ »
This was to test you... ;)
You are right.
