Domiq/Base - das gesuchte intelligente PK mit Ethernet?
#11 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon Philipp » So 7. Feb 2010, 12:47
Hi Nils,
ich hätte lieber eine volle Integration des gesamten PCHk Protokolls, und keine Doku ;)
Schade, da die Kiste alles hat was für eine sauber Busankopplung benötigt wird:thumbup:
Nur bringt mir eine weiteres individuelles Protokoll nichts.
norden
#12 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon norden » So 7. Feb 2010, 13:09
sehe ich auch genauso, eine Anbindung mit vollständigem Protokoll und eine Gateway-Funktion
auch für andere Applikationen (IP-Symcon) wäre schon klasse!
Dieter
#13 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon Philipp » So 7. Feb 2010, 13:11
Hello Filip,
thanks for your answer.:)
domiq hat geschrieben:to answer your questions: yes, Base has dedicated processor to handle LCN bus timings, collision detection and checksumming.
:thumbup: That's exactly what I'm (an I'm sure also others) looking for.
domiq hat geschrieben:While our PCHK implementation is limited only to binary mode,
:cry: and that's the problem, I would like to have a full PCHK support, so that I can connect through a third party tool which supports the PCHK commands.
I can understand that from your point of view your "own" command interface is the better way, even to include the functions of the Touchscreens in the same way. But with a full supported PCHK protocoll also users of third party tools would be able to use your LCN-IP Gateway. And from my perspective this is not a replacement of Moduls or software which is already provided by Issendorff. There's today no such Intreface which provides "handle LCN bus timings, collision detection and checksumming" directly on the hardware. So this would be IMO a clear step forward.
regards
Philipp - still searching for a stable way to connect the LCN world with the IP world
#14 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon Uwe » Mi 24. Feb 2010, 01:22
Ich hab's dann mal probiert.
Port 4114 ist am Base durchaus offen für einen Zugriff mit der Pro. Ein Zugriff von IPS wird leider nicht mit Daten beantwortet ... :(
norden
#15 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon norden » Mi 24. Feb 2010, 07:14
bist Du dabei auf Einschränkungen im Befehlssatz gestoßen?
Gruß aus Kollmar
Dieter
#16 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon Philipp » Mi 24. Feb 2010, 11:39
Ich denke dass hat Filip oben schon geschrieben, dass nur die Pro Kommunikation über den Port geht.
norden
#17 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon norden » Mi 24. Feb 2010, 23:17
Sorry Philipp,
ich wußte nicht, daß Du das Base schon selbst getestet hast.
Ich war nur skeptisch, da Herstellerangaben und die Realität auch manchmal differieren;)
Ich habe mir eins bestellt und bin schon sehr gespannt ob die Pro vollständig unterstützt wird.
Bis dahin
Dieter
#18 RE: Domiq/Base - das gesuchte intelligente PK mit Ethernet?
Beitragvon Philipp » Mi 24. Feb 2010, 23:22
Hallo Dieter,
nee, da warst Du schon richtig unterwegs, ich habe die Base selbst bisher nicht getestet. Ich habe aber bei Filip genau diesen Punkt angefragt, da ich gerne IPS über das Base gekoppelt hätte. Seine Aussage war aber klar, dass das nicht funktionieren wird.
Bin gespannt, was Du mit dem Base diesbzgl. alles testen und rausfinden kannst.
Gruß Philipp - weiterhin mit einem PK am seriellen Port und PCHK1.0x
