Hi Filip, hi all,
one more question, if allowed ;-)
Is it possible to use DELAY or TIMER commands from the logic module? I want to create a timer based callback, and DELAY or TIMER commands would be really helpful instead of programming a timer by myself.
Something like
use abc = "TIMER.room.5s.C.LOGIC"
abc.value = "mycallback(parameter)"
If yes, do you have some sample code? I tried some variations of above, but no success ;-)
Any other options?
Have a nice evening,
Best regards,
timers / delay from logic
DOMIQ
#2 RE: timers / delay from logic
You could use timers like below:
function handler(test)
print("This is delayed " .. test)
end
command("TIMER.test.5.C.LOGIC=handler('Hello')")
twinkelm
#3 RE: timers / delay from logic
That is an elegant solution, just what I was expecting, thanks a lot. And especially thanks for the super fast reply!
Best regards,
Best regards,
DOMIQ
#4 RE: timers / delay from logic
Sorry, I just found one reason why that will not work.
Next version of the system will have it fixed. As for now command call is adding C. in front.
As a workaround until it's fixed you can add following line to the Events tab:
This will forward any data sent to C.TIMER.xxx=yyy as TIMER.xxx=yyy. You can try the same approach with delays.
Channel: C%.TIMER%.(.+)
Command:
Channel name: TIMER.$C1
Channel value: $D0
