Update 1.8.0.1
DOMIQ
#1 Update 1.8.0.1
Hello, we released today update 1.8.0.1. Most important changes are fixes for the networking APIs, and for SONOS. It is now required to select "UPnP AV Enabled" on the Settings tab in order to have working SONOS integration.
Matthias_@_Home
#4 RE: Update 1.8.0.1
Azimuth und notify laufen auch wieder? (Bin noch auf 1.7.8, daher diese Fragen.)
DOMIQ
#6 RE: Update 1.8.0.1
Now you even have 1.8.0.2. This one fixes obscure bug in our LCN code, which could have resulted in packets being sent twice or misses in some cases.
#7 RE: Update 1.8.0.1
Na super. Bei mir geht heute um 16:54 die Sonne unter...
Gibts eine Möglichkeit, doch wieder 1.7.8 zu downdaten.
Matthias_@_Home
#8 RE: Update 1.8.0.1
Gib mal unter Einstellungen Deine Koordinaten (Ort) neu ein. Das Problem hatte ich auch....
DOMIQ
#9 RE: Update 1.8.0.1
Make sure you have geo position filled correctly - most probably latitude/longitude needs to be swapped.
Unfortunately, we couldn't swap this automatically as those were two bugs in two different versions that were "cancelling" each other...
#10 RE: Update 1.8.0.1
Jetzt gehts
Geodaten waren schon angegeben, aber erst nach einem Base-Neustart aktiv.
