This will enable us to rewrite a lot of internal software in a much more efficient way, but will also make it possible to expose full networking stack in the Logic. You will be able to code things like:
local srv = tcp.socket()
srv:bind(1234)
srv:mode('line')
srv:on('connect',function(skt,addr,port)
print('Connection from '..addr..':'..port)
skt:on('line',function(data)
print('Received: '..data)
skt:send('You wrote: ' .. data)
end
skt:on('error',function(err)
print('ERROR: '..error)
end
skt:on('close',function()
print('CLOSED')
end
skt:send('Type something!')
end
srv:listen()
local t = timer.periodic(1,function()
print('Another second')
end)
