No IP/ Webcamstream in DOMIQ remote app Android
DOMIQ-Support
#11 Re: No IP/ Webcamstream in DOMIQ remote app Android
Beitragvon DOMIQ-Support » Mo 8. Aug 2022, 11:40
It's just an example :)
If you open Developer Console and then navigate to the Network tab then make a request to stream camera video. You'll see the request and then if you click on it, you'll see headers on the right side of the window :)
#12 Re: No IP/ Webcamstream in DOMIQ remote app Android
Beitragvon LCNNoob » Mo 8. Aug 2022, 17:48
Hello Team,
I understand your hints. But this what you mentioned is not shown in my console with my camera.
I'm not able to attach a screenshot in the forum. Maybe with screenshot it would be easier to understand what I do see in my console. It is different. There is e.g. no entry "login.do" where I then can click to Header.
Greets LCNNoob
DOMIQ-Support
#13 Re: No IP/ Webcamstream in DOMIQ remote app Android
Beitragvon DOMIQ-Support » Di 9. Aug 2022, 11:24
You won't see login.do because it's a request that our configurator does :) In case of your camera you'll see some other requests.
Please contact me over e-mail, I'll lead you ;)
#14 Re: No IP/ Webcamstream in DOMIQ remote app Android
Beitragvon LCNNoob » Di 9. Aug 2022, 20:13
Thank you. I will come back to you if I have more time for investigation. I think beginning of October.
See you
#15 Re: No IP/ Webcamstream in DOMIQ remote app Android
Beitragvon LCNNoob » Sa 28. Jan 2023, 15:48
So back again with this issue. Not October, but so what.
I need to get this camera to work with DOMIQ. Stream works if I switch on Anonymous Login allowed in camera settings.
If Anonymous Login is disabled, the stream is not shown.
So if possible I need some help with this problem.
Thanks
