Hello, we don't usually make a big noise about minor releases, but this time it includes very, very small fix for a big, big issue for some of you. As was discussed on some threads, Base was periodically hanging/restarting in some installations.
Over last few weeks we managed to replicate, hunt down, find and fix the issue - a small memory leak in very old API used to query Base serial number, which was most frequently used in response to M-SEARCH UPnP queries. As usual, replicating was the hardest part, fixing the easiest. Enjoy!
Update 1.8.4.3
#2 RE: Update 1.8.4.3
Hallo Filip,
mal sehen wie die Version läuft, habe da nach den Test's, ein gutes Gefühl.
