iPod Kopplung LCN / DOMIQ
Sven
#11 RE: iPod Kopplung LCN / DOMIQ
Beitragvon Sven » Sa 2. Mai 2009, 01:27
@DomiQ:
That seems to be a nice Product.
Is it possible to create a german Version of your software or translating the description into german?
That seems to be the gateway we search for :-O
KeineInfo
#12 RE: iPod Kopplung LCN / DOMIQ
Beitragvon KeineInfo » Sa 2. Mai 2009, 11:10
I tried to download all our PDFs, and they seem to work. @F2, can you hint which had issues?
We should have English translation available by the end of next week. Regarding sales and availability, until we establish partner network in Germany, product is available directly from us, we have modules on stock. As this would be intra-EU transaction, if you order as as individual we will add 22% VAT, if you give us VAT-EU number we don"t charge VAT, you pay it yourself :-)
We ship by UPS, either as prepayment or charge on delivery. For owners of LCN-MKO we have special deal - please ask by mail.
Our module works "alone", that is it doesn"t need any external components like PC, it also doesn"t need LCN-PK and LCN-PCHK. Everything fits in 4T case, we spent awful lot of time squeezing things to fit there :-D It does use around 50mA@230V. :-)
Another thing is that for remote control of your installation no public/fixed IP numbers are required.
KeineInfo
#13 RE: iPod Kopplung LCN / DOMIQ
Beitragvon KeineInfo » Sa 2. Mai 2009, 12:10
One more thing - for German translation we would like to have it done by local partner. That shall happen in each country. We would like to avoid situation, where translated content is less understandable from original. Both DOMIQ/Remote application as well as configuration console of DOMIQ/Base can change language based on user configuration.
KeineInfo
#14 RE: iPod Kopplung LCN / DOMIQ
Beitragvon KeineInfo » Di 5. Mai 2009, 00:06
Hello,
we just added new feature - integration connection. Those are plain TCP connections, that do output "property style" notifications on each event from LCN, MODBUS and Intrusion Detection systems. To control those standard XML format is used, that we use inside all of our XML configuration files (timers, events, etc)
Example:
LCN.output.0.130.1=100
LCN.output.0.130.1=98
LCN.output.0.130.1=84
LCN.output.0.130.1=82
LCN.output.0.130.1=70
LCN.output.0.130.1=68
IDS.input.23=1
LCN.output.0.130.1=66
LCN.output.0.130.1=54
LCN.output.0.130.1=52
IDS.input.23=0
LCN.output.0.130.1=50
Should make integration with other solutions easier :-)
We also have tag, that does allow sending of any LCN/MODBUS data.
What do you think about such interface? Of course, any number of clients can connect concurrently.
KeineInfo
#15 RE: iPod Kopplung LCN / DOMIQ
Beitragvon KeineInfo » Do 7. Mai 2009, 17:32
Hello, I have good news - we published English version of User Guide for DOMIQ products.
http://domiq.pl/attachments/015_DOMIQ%2 ... Manual.pdf
KeineInfo
#16 RE: iPod Kopplung LCN / DOMIQ
Beitragvon KeineInfo » Sa 16. Mai 2009, 19:58
vielleicht mach ich ja etwas falsch, aber sobald ich auf die Homepage gehe und dort versuche die PDF zu öffnen
habe ich entweder nur eine weiße Seit oder aber in der Bedienungsanleitung sind beschriebene Seiten mit weißen Seiten gemischt :confused:
Hat von Euch schon jemand das Modul ausprobiert???
Gruß Frank
#17 RE: iPod Kopplung LCN / DOMIQ
Beitragvon Thomas » Sa 16. Mai 2009, 21:54
Hallo Frank,
bei mir werden die Seiten angezeigt : [url]http://domiq.pl/attachments/015_DOMIQ%20-%20User%20Manual.pdf
[/url]
*edit by Uwe: nutz doch den Hyperlink (die Weltkugel), dann kann man doch direkt klicken :P
KeineInfo
#18 RE: iPod Kopplung LCN / DOMIQ
Beitragvon KeineInfo » Mo 29. Jun 2009, 00:31
ich wollte mich mal erkundigen ob es schon erste Erfahrungsberichte gibt.
Gruß Frank
#19 RE: iPod Kopplung LCN / DOMIQ
Beitragvon Uwe » Mo 29. Jun 2009, 01:30
Hallo Frank,
nach meinem Kenntnisstand hat noch kein deutscher Bus-Profi das Modul testen können.
Die Suche von Filip nach einem Vertriebspartner für Deutschland werden wir wohl unterstützen. Es müssten "nur noch" die Konditionen ausgehandelt werden.
@Filip: I'll answer your Email soon (when i'm back at home)
Danksagung erhalten: 11 Mal
#20 RE: iPod Kopplung LCN / DOMIQ
Beitragvon Thomas.Einzel » Mo 3. Aug 2009, 22:37
Hallo Uwe, ich habe mir das Programm mal gerade auf dem iPod istalliert - ja ist schon ärgerlich dass da nur 4TE inder Verteilung fehlen. Allerdings sehe ich für "650 EUR + VAT" nur eine eingegrenzte Zielgruppe.
Mich wundert, dass das http://domiq.pl/en/products/domiqbase.html eine LAN - LCN Kopplung hat, aber "Hello, we had Prof. Issendorff visit us during his trips to Warsaw. He really liked our product :-)" D.h. er wußte vorher nicths davon... naja, egal, nicht meine Baustelle.
Ist das unten rechts eigentlich ein T- oder P-Port? :rolleyes:
Uwe, was macht denn dein Wettbewerbsprodukt? Sieht es auf dem iPod mittlerweile ähnlich aus? Ich hatte mir mit domiq remote gerade eine Seite mit einigen Temperaturwerten gleichzeitig angezeigt, so etwas möchte ich schon lange...
