Problem with LCN-AVN
#11 RE: Problem with LCN-AVN
Beitragvon Uwe » Do 28. Jul 2011, 00:43
In Lower Saxony, we say at any time of day (or night) 'Moin Moin' :D
No, I don't think so. You have to check the voltage at the module and at the AVN.
Your installer should find the problem then - but a broken AVN is also not impossible ...
Good luck
edubht
#12 RE: Problem with LCN-AVN
Beitragvon edubht » Mi 10. Aug 2011, 18:49
Hi!
There was a failure in the installation, now with this configuration are working properly.
Thanks!
#13 RE: Problem with LCN-AVN
Beitragvon Uwe » Mi 10. Aug 2011, 23:31
Thanks you for your feedback - it is a pleasure to read that it works now :D
Best regards, Uwe
