access control with domiq
#1 access control with domiq
while evaluating, if domiq might be the right control system for a new installation, can you do access control?
Do you receive the UTL codes and can evaluate them (more than the maximum of 8 keyes in an UPP module)
Regards Florian
DOMIQ
#2 RE: access control with domiq
Beitrag von DOMIQ »
Hello Florian,
if you make modules sent transponder codes to the LCN bus, those will appear as below:
E.LCN.transponder.0.XXX=A1 hit 12345678
If you do some rules in Events tab, you could use that to implement access control system.
We would be happy to create tutorial together with you how exactly that should be implemented (we don't have transponders at our office and we like to create tutorials based on real needs).
#3 RE: access control with domiq
Wir probieren das in meinem Koffer, Florian.
Ich muss den nur erst noch mal wieder aufbauen ... ;)
Grüße, Uwe - ... will be happy together ... :w00t:
lcn_iberica
#4 RE: access control with domiq
Beitrag von lcn_iberica »
It would be great that DOMIQ can just recieve transponder code and manage it directly, to have a more powerful access control than the one in LCN modules (just 16 codes, no access rights, etc.).
Maybe an Access Control tab can be implemented in the next version of Base firmware?? :P
