is für die Zukunft eine Ablösung von Flash angedacht, z.B. durch schickes Ajax? Ich finde Flash nicht mehr ganz optimal und zeitgemäß, es gibt da eigentliche sinnvollere Standards die Browser auch ohne Addons supporten.
Claus
Roadmap Domiq
#2 RE: Roadmap Domiq
Hello, there are no plans to change this. Flash/Flex works perfectly for what we need and it's pleasure to program in.
What might happen at some time is that new configuration app will appear, that will use Air and be standalone to allow offline configuration and management of large, distributed networks of Bases.
- Danksagung erhalten: 3 Mal
#3 RE: Roadmap Domiq
Hello,
problem is a missing app for Android devices, menas smartphones and pads. From a regular desktop flash is not bad but from the small devices it's slow and an app would be much better. But i just found an app for ipads and iphones.
#4 RE: Roadmap Domiq
Then why don't you ask about creation of Android app - which actually is in the plans and being worked on
#5 RE: Roadmap Domiq
Good question
Will the app work on pads too? Means using the whole screen size to visualize the building?
#6 RE: Roadmap Domiq
Yes, we want to have Android Remote that will do everything iOS Remote does.
I believe that in order to provide good usability native apps are the only solution. It's just expensive and time consuming to create them, that's why we concentrated on iOS first.
#7 RE: Roadmap Domiq
It's good to hear you would like to support Android devices. Is there any way to connect to LCN accross the Domiq Base and control LCN? Means switch on/off lights with a Linux shell script i.e.
#8 RE: Roadmap Domiq
Of course, you can use port 4224.
For example, to toggle lights from Linux:
All details are included here: http://domiq.pl/attachments/015_DOMIQ%20%20Channels.pdf
echo LCN.output.0.20.1=toggle | nc yourbaseip 4224
#10 RE: Roadmap Domiq
[zitat]Yes, we want to have Android Remote that will do everything iOS Remote does.[/zitat]
Is there any timeline when an Android app will be available?
