Zugang mit LCN-PRO über Domiq schlecht
DOMIQ-Support
#11 RE: Zugang mit LCN-PRO über Domiq schlecht
Can you (just for tests) temporarily disable UPNP in Base (you need to uncheck the UPNPAV checkbox in the Settings tab) and see if the problem still occurs? Remember to save the Settings tab and restart module after that. Some of you mentioned about many errors during scan, please paste a portion of logs where those errors are present. Did you observe any errors in Discover tool?
#12 RE: Zugang mit LCN-PRO über Domiq schlecht
I disabled UPNP on the base and after 3 days I still have good connection with the LCN-Pro.
No errors occurred during reading the configuration.
It seems likely that this is not just a coinsidence.
What are the next steps so that I can use SONOS again with the Base?
Xtof
Xtof
DOMIQ-Support
#13 RE: Zugang mit LCN-PRO über Domiq schlecht
I'm already working on it and believe it will help your problems.
@Xtof - how many Sonos players do you have?
#14 RE: Zugang mit LCN-PRO über Domiq schlecht
Hello Piotr,
1 Bridge
1 Connect
2 Play 3
2 Play 1
Best Regards
Xtof
1 Bridge
1 Connect
2 Play 3
2 Play 1
Best Regards
Xtof
#15 RE: Zugang mit LCN-PRO über Domiq schlecht
As an update:
yesterday I had a bad connection (the first time after a couple of weeks) even that the UPnP was disabled the whole time.
Xtof
Xtof
DOMIQ-Support
#16 RE: Zugang mit LCN-PRO über Domiq schlecht
If you encounter this situation again please log in into Base using telnet (login and password is the same as for configurator) and type these commands:
list
tcp
netstat tcp
mall
And then copy the results and send it to me (pdukowski@domiq.pl).
list
tcp
netstat tcp
mall
#17 RE: Zugang mit LCN-PRO über Domiq schlecht
Small update: both PCK connection issues as well as SONOS "capacity" will be improved in next software update, currently in beta testing.
#19 RE: Zugang mit LCN-PRO über Domiq schlecht
Good to hear, had the same issues not being able to read LCN via base around Christmas. Though I'm wondering if the update will bring a solution to this because I don't use Sonos and UPNP isn't enabled as well..
#20 RE: Zugang mit LCN-PRO über Domiq schlecht
Hello,
I experienced the connection problem again without Upnp being activated.
I tried to document this using hyperterminal connection but could not send the proposed commands as my base frequently overwrites the input by cyclically sending counter variables.
Is there another way to get connected so I can contribute with a log?
Besides: Is there somthing like a lua editor that can remotely debug the code?
Xtof
Xtof
Mitglieder in diesem Forum: 0 Mitglieder und 31 Gäste
