cURL , HTTP Post
koboldo
Hat sich bedankt: 7 Mal
#1 cURL , HTTP Post
Beitragvon koboldo » Fr 13. Feb 2015, 07:41
gibt es eine Möglichkeit solch einen Befehl aus dem Domiq zu senden ?
curl --header "Content-Type: text/plain" --request PUT --data "OFF" http://192.168.100.21:8080/rest/items/MyLight/state
:confused:
DOMIQ-Support
#2 RE: cURL , HTTP Post
Beitragvon DOMIQ-Support » Fr 13. Feb 2015, 08:17
Yes, you can use HTTP.get command in Base. The syntax is as follows C.HTTP.get=url, where url should be replaced with valid URL. You can pass any arguments in the url.
koboldo
#3 RE: cURL , HTTP Post
Beitragvon koboldo » Fr 13. Feb 2015, 08:20
Hallo Piotr,
http.get habe ich schon öfter benutzt, wie kann ich der url aber mitgeben das es ein put request ist und -- data "OFF" ?
:cry:
DOMIQ-Support
#4 RE: cURL , HTTP Post
Beitragvon DOMIQ-Support » Fr 13. Feb 2015, 11:06
is the PUT method required by the receiver of data? If not, you can use the GET method to pass data using the query string ?name=value
koboldo
#5 RE: cURL , HTTP Post
Beitragvon koboldo » Fr 13. Feb 2015, 11:19
Yes, it is required to write things direkt to the rest api of the receiver.
DOMIQ-Support
#6 RE: cURL , HTTP Post
Beitragvon DOMIQ-Support » Fr 13. Feb 2015, 12:22
Right now, it's not possible to use PUT or POST methods, but we will add it in near future. I think it will be available in the Logic and as a command.
koboldo
#7 RE: cURL , HTTP Post
Beitragvon koboldo » Mo 16. Feb 2015, 09:26
That sound´s good :thumbup:
I hope in the near future is quicker than it is with the HUE http://www.bus-profi.de/index.php/forum/topic/4932.html Integration...
since 07/13....:-/
