Hi Filip,
hope you are doing well!
One short question on using the "regulator with channels" in the iPhone interface - for some reason, I am not getting it to paint the graph. I am assigning two values, VAR.current and VAR.tobe, and it should paint the graph of VAR.current, but it does not. Seems like it does only like LCN.value graphs?
Is this behavior intended?
If so, I think there is no other option to paint a graph from an arbitrary value, right (not only from temperatures, but, say, also from percentage values of an output)?
Many thanks for letting us know,
Best regards from cold Germany,
Regulator and channels
#2 RE: Regulator and channels
Hello, currently history is only stored for values (r1,r2,current). You can make graphs for something else by redirecting events like below:
Channel: E.VAR.anything
Match:
Command - send channel
Name: E.LCN.value.0.88.1 Value: $D0
Where 88 is module ID that does not exist![Lächeln :-)](./images/smilies/icon_e_smile.gif)
Match:
#3 RE: Regulator and channels
Thanks a lot,
that works nicely. The only "issue" (well, not really) is that in the Domiq iPhone Application GUI I get in the display "---.-" after a few secs, but the graph paints fine.
Have a nice remaining weekend,
Best regards,
Best regards,
#4 RE: Regulator and channels
To fix the "issue" you could replace channel send with following:
What it does?
Anything sent to C.LOGIC is executed as Lua code inside Logic screen. Function set can be used to update any state value, exactly this code is called by built-in LCN packet decoder. When such state value is changed, notification (E.) will be sent automatically, so previous channel code is not needed. You saw ---,- because previous code I sent did not change "state" of the Base, which is loaded now and then by the Remote. You can check out entire state by opening: http://BASE_IP/state.xml
Value: set('LCN.value.0.88.1',$D0)
What it does?
#5 RE: Regulator and channels
Great Filip,
thanks a lot. I am currently away (Hotel where the VPN is not working) but will try later this week. Also thanks very much for explaining, it really becomes clearer how the base works. You know that you are "super class" with your customer support, very rare to see something like this for a commercial product.
State.xml is a really nice thing, much nicer than typing "?" in the telnet interface, also from an integration point of view. Much easier to integrate and also much easier to extract the actual values for doing some post processing, such as recording in a database or doing some more fancy graphics with rrdtool.
Have a nice week,
best regards,
Have a nice week,
best regards,
