Letztes Update
mr_claus
#1 Letztes Update
Beitrag von mr_claus »
Hat jemand ein Changelog zum letzten Base Update?
#2 Re: Letztes Update
Beitrag von LCNNoob »
3.0.0.8 25.03.2024
Today we published an update for DOMIQ/Base modules.
1. Implementation of the DALI2 protocol for DT8 devices. Added support for the RGB and TC control types.
2. Enhanced variables binding in events and timers - much easier creation of complex conditional statements and commands. We also fixed arithmetic expressions assigned to commands.
3. Rebuilt handling of MODBUS RTU and MODBUS TCP/UDP - more reliable operation and less RAM memory consumption.
4. Fixed handling of commands for controlling LCN relays with timers.
LCN.relay.S.M.P=1;timer:<time_in_miliseconds>
5. Added command for locking LCN relays
1. LCN.relay.0.10.1=lock/unlock/softlock
2. LCN.relays.0.10=LLSSUU—, L -> lock, S -> soft lock, U -> unlock, - -> do not change.
6. Fixed locking of LCN keys:
1. LCN.locks.S.M.T=1100UU—
2. Status information about locked keys are now available in the State of Base module. Therefore it’s also possibile to define events based on this information from now on.
7. We added an event which is triggered after the scan of the LCN bus is completed.
Event syntax: LE.SYSTEM=lcnready
Event example:
1. Channel: LE.SYSTEM
2. Data: lcnready
3. Actions -> define any action you would like to perform when LCN scan is finished.
8. We added support for QoS=1 and other minor improvements in MQTT broker.
9. Fixed handling of Shelly gen.2 and gen.3 devices.
mr_claus
#3 Re: Letztes Update
Danke, aber es gibt noch ein weiteres Update, zu diesem finde ich keine Details.
#4 Re: Letztes Update
Stimmt. Es wären sogar 2. Bei mir ist die 3.0.1.0 drauf.
Aber dann weiß ich es auch nicht.
mr_claus
#5 Re: Letztes Update
Ich hatte folgende Antwort von Piotr erhalten ...
RTOS - fixed reading of pak files.
systempak - fixed handling of arithmetic expressions in events/timers.
#6 Re: Letztes Update
:thumbup:
TK-T
#7 Re: Letztes Update
Beitrag von TK-T »
Schon Mitbekommen? DOMIQ/Base-Update – Systempak 3.0.1.1 – Erscheinungsdatum: 10. September 2024
Es wurden eine Reihe von Verbesserungen und neuen Funktionen eingeführt, die den Benutzerkomfort und die Integrationsmöglichkeiten verbessern. Hier die wichtigsten Änderungen:
1. Verbesserter Mechanismus zur Handhabung von MEM-Variablen.
2. Unterstützung für Gruppenbefehle für die DALI RGB- und DALI TC-Steuerung hinzugefügt.
3. Fehler bei der Anzeige des LCN-Tastensperrstatus behoben.
4. Unterstützung für LEDs in LCN-Modulen hinzugefügt.
Befehl: C.LCN.lamp.seg.id.1-12=on/off/blink/flackern
Der LED-Status ist unter der gleichen Kennung verfügbar (ohne das C-Präfix).
5. Unterstützung für den LED-Gesamtstatus für LCN-Module hinzugefügt. Ihr Status ist unter der Kennung: LCN.ledsum.seg.id=all/partial/0 verfügbar. „all“, wenn alle in der Summe angezeigten LEDs den erwarteten Wert haben, teilweise, wenn nur einige von ihnen, 0, wenn die Summe nicht erreicht wird.
Der aktuelle Status des Identifiers wird im Basismodul-Konfigurator im Reiter Status angezeigt. Der LED-Gesamtstatus kann standardmäßig zum Auslösen von Ereignissen im System verwendet werden.
Xtof
#8 Re: Letztes Update
Beitrag von Xtof »
Hallo und Danke für den Hinweis,
leider posted DOMIQ auf der Webseite keine Informationen über die Updates mehr. Auch die Seite selbst scheint stehengeblieben "(c) 2023".
Woher habet Ihr die Infos zu den Änderungen und neuen Funktionen? Gibt es Näheres dazu?
Xtof
TK-T
#9 Re: Letztes Update
Beitrag von TK-T »
die Infos hab ich mit Google-Hilfe auf der polnischen Homepage gefunden: https://www.google.de/search?q=domiq+3.0.1.1
Auch die Homepage ist dort um einiges aktueller. Einfach mal auf https://www.domiq.pl/de/ umschauen.
