Hello Filip,
I tryed to use some formatf - commands in the configuration of the display. I have 2 questions:
1. %f Is this correct, that I only have to write %f ? The result is 536,0 insteat of 536.
2. Do you have a syntax for a time like 16:00 ? I'd like to write the sunset - time in the display and without a format is the result 16,0 insteat of 16:32.
Thanks for your help in advance...
formatf im Display
