formatf im Display
Franky
#1 formatf im Display
Beitragvon Franky » Sa 12. Nov 2011, 16:44
Hello Filip,
I tryed to use some formatf - commands in the configuration of the display. I have 2 questions:
1. %f Is this correct, that I only have to write %f ? The result is 536,0 insteat of 536.
2. Do you have a syntax for a time like 16:00 ? I'd like to write the sunset - time in the display and without a format is the result 16,0 insteat of 16:32. :)
Thanks for your help in advance...
DOMIQ
#2 RE: formatf im Display
Beitragvon DOMIQ » Sa 12. Nov 2011, 20:54
You can use Text element - fill channel field. Value is for numbers...
Franky
#3 RE: formatf im Display
Beitragvon Franky » Sa 12. Nov 2011, 23:51
Thank you, it works.:)
